how to connect and install ricoh aficio 220
  • daqid
    #16
    Re: how to connect and install ricoh aficio 220
    Ah I see. The only thing I was hoping to achieve is to be able to scan more than one page at a time so I can create pdfs. Oh well I guess it is a big door stop now lol. Thanks for all the help.
      • 23008
      #17
      This particular machine has many features:
      It's slow
      It's expensive to operate
      The consumables have a very short yield
      By now the consumables are not available.
      Perhaps if you leave it out by the street someone will steal it, and you won't have to pay for disposal?
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        #18
        It's an old black and white POS!!!! they were throwing it away for a reason!!!!! parts and supplies were discontinued by Ricoh years ago, the aftermarket will be your only salvation if there is any.....................
        Mystic Crystal Revelations
          • 37490
          #19
          From looking at the pictures you provided, what you have is an old Product code A265 machine. As I only see Copy and Printer buttons above the Start Button, this machine does not have FAX or Scan function. As for USB, it was an option at the time this model was available. If network printing does not work it could be a number of things. The port controller on the NIB could be bad. The NIB might not be fully seated on the Printer controller board. If the only print driver you found is for USB, you found the wrong model to download. Try this link: http://www.ricoh-usa.com/downloads/p...2fx22_27en.htm
