Toner supply pump Ricoh mp 1100
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 169
    [CQ] Toner supply pump Ricoh mp 1100
    I just asked that toner supply pump should be smooth when turn around it with my free hand?
    With my greeting.
    • 37052
    Re: Toner supply pump Ricoh mp 1100
    Usually a new pump that has never had toner in it can be turned but has some resistance to turning. Once it has toner in it, it becomes much harder to turn. That is why they have a fairly good sized motor driving it.
      • Mar 2012
      • 169
      With my greeting.
      By taking in mind that the machine is restart after a few copies (200 copies) then dislpay sc 495
      • mikadonovan
        • May 2008
        • 2931
        Be sure and vacuum out the toner supply tube. It may be clogged.
        NEVER ASSUME ANYTHING
          • Mar 2012
          • 169
          I done as your advise but no result i also vacuumed toner hopper.
          With my greetings.
          • Codex
            • May 2008
            • 694
            Had same problem...change toner supply pump ant thats it.Dont forget to do a Toner Bank Setup after replacing the pump
            Memento Audere Semper
