ricoh 2051 print repeating
  • Elmo
    • Feb 2010
    • 541
    #16
    Re: ricoh 2051 print repeating
    check the fusing unit if you are not a tech call one this is not a user job
    I Used To Live To Fix Things Now i Fix Things To Live
    • fbkhan3
      • May 2012
      • 421
      #17
      Originally posted by ramana2323
      Ricoh 2051 is the model print and copies are getting duplicated towards the end of the page
      If i'm not mistaken this should be Ricoh MPC2051..is it??
      Well if you can rub off the image from paper as you said then it's definitely a Poor Fusing Issue specially the Pressure Release Locks on both sides in the Fusing Units.Make sure one of them isn't broken..
      HTH
      Regards
      • mikadonovan
        • May 2008
        • 2931
        #18
        You need to check your paper type in the print driver settings as well as checking the fuser.
        NEVER ASSUME ANYTHING
        • fshead
          • 2376
          #19
          sir
          what is the solution ..?
          you need a new "defizzler unit"
          • CRISTIAN MULLER
            • Feb 2013
            • 145
            #20
            try print with thick paper selected on driver, don't forget to change in copier too.
            • ramana2323
              • Sep 2014
              • 10
              #21
              [ATTACH=CONFIG]26371[/ATTACH]
              HTH
              Regards
              sir
              Is there anything in the Printer to be adjusted like fusing temperature at he beginning of the paper and the end of the paper
              as you can see the images attached the image is getting fused properly for nearly 80% of the sheet of any microns
              only the last 20% is getting scattered
              the Pressure Release Locks are fine I have checked them
              thanking you
                • 37553
                #22
                My guess would be that temperature of the pressure roller dropping during copying. Check for an open pressure roller thermostat or the pressure roller thermistor loose or out of position.
                • fbkhan3
                  • May 2012
                  • 421
                  #23
                  sir
                  thanking you
                  There are 100 of SP settings related to Fusing temperature but it's never a good idea to play around.
                  Service manual has it all and you need to read through the FSM before attempting those settings.
                  Are you using OEM or Original Ricoh Toners?
                  Regards.!
                  • ramana2323
                    • Sep 2014
                    • 10
                    #24
                    Regards.!
                    sir
                    I am using original ricoh toners only
                    thanking you
                    • fbkhan3
                      • May 2012
                      • 421
                      #25
                      Instead of playing around with Fusing temperature just try to change the paper type to Thick 1 or Thick 2 that will reduced the Machine speed but let's see if that makes any difference?
                      Regard's
                      • fshead
                        • 2376
                        #26
                        Is there anything in the Printer to be adjusted like fusing temperature at he beginning of the paper and the end of the paper>>
                        a tec would never ask that question..
                        this is a end user trying to avoid paying for a service call.
                        plus it would good idea to know what model machine as i cant see a b/w 2051 wth 9k
                          • 37553
                          #27
                          I agree the original poster must be an end user or an IT person. The machine is a MP C2051, the attachment to post 4 is in color.
                          • fshead
                            • 2376
                            #28
                            i like others here will at times help those non tec if it there is a level of real need..ie a non profit or such...
                            here we have someone who can afford to buy a new machine but not the service call...?????
                            time to reach inside your pockets..make the call, write the check..
                            we all cant be astronauts
                            • ramana2323
                              • Sep 2014
                              • 10
                              #29
                              Sir
                              by the way you Respond and Address the problem
                              Everybody here in the forum can understand that you don't have proper knowledge about the machines
                              Rather you are More concerned about the A person's pockets instead of Addressing the Problem
                              You are commenting whether Can he buy a new Machine or Can he Afford to pay for A Service Call
                              If you are unaware of the problem simply Keep Silent
                              Sometimes Even a Senior Service Engineer Cannot solve the Issue.......PL note that
                              Thanking you
                              • fshead
                                • 2376
                                #30
                                Sir
                                Thanking you
                                yes as you cant even post which machine "ricoh 2051"you are asking for "free" tech support..or
                                even post a proper copy of your issue..
                                you are like the guy who comes to dinner empty handed and afterwards complains that the food sucked..now where is my dessert???
                                you are NOT a tech,you bring nothing.you have a new ish machine that normally should be under warranty\
                                "unless you bought it off the back of a truck",that doesnt work as it should.
                                .if you stated you have no clue on copier function or
                                such i d be inclined to respond differently but instead you dance around expecting me to read your mind..
                                RHAMEN I am done with you and i dont have proper knowledge about the machines..
                                hire a tech you cheapo...............
