ricoh 2051 print repeating
  • ramana2323
    • Sep 2014
    • 10
    [CQ] ricoh 2051 print repeating
    Ricoh 2051 is the model print and copies are getting duplicated towards the end of the page
    • 37385
    Re: ricoh 2051 print repeating
    I could not see what you are asking about in the attachment. Next time circle the problem and indicate the direction of paper travel.
    Most offsetting occurs in the fusing unit. Fusing temperature might be either too high or too low. Fusing belt may be old and has toner build up on it.
    • sandmanmac
      • 3979
      Agreed. Likely Fuser, but Whatever the case, You need a tech
      • ramana2323
        • Sep 2014
        • 10
        [QUOTE=slimslob;435638]I could not see what you are asking about in the attachment.
        sir
        I have clearly indicated with arrows the line diagram fizzled out towards the end of the print
        same is the case even if we take a Xerox copy new attachments provided
        thanking you
        • Iowatech
          Not a service manager
          • 3930
          It looks somewhat like your CAD program isn't erasing the set up lines correctly.
          See the dimension lines on the left side of the the top of your first picture. There is one there that indicates a vertical dimension that has to do with the distance between the top of the illustration and one of broken lines that best I can tell shouldn't be there.
          I could be wrong, but I think the 2051 has nothing to do with this problem, it is just printing what your CAD program tells it to.
          • ramana2323
            • Sep 2014
            • 10
            sir
            pl check the fresh images attached
            • Polarbear
              • Feb 2012
              • 1070
              What paper is this copied onto? Is it bond or glossy?
              Press the GREEN button!!
              • Elmo
                • Feb 2010
                • 541
                Looks very like a paper issue moisture/humidity in the paper
                will be forced towards the end of the page
                by the heat and pressure from the fusing unit
                I Used To Live To Fix Things Now i Fix Things To Live
                • ramana2323
                  • Sep 2014
                  • 10
                  sir
                  I have used 80 gsm, 100gsm, 200gsm paper same is the problem 80% print is ok the last 20% image not fusing properly or image is not getting properly transferred
                  pl suggest thanking you
                  • Elmo
                    • Feb 2010
                    • 541
                    a few things to look at when was the machine last serviced
                    what are the pm counts on the drum/developers
                    • ramana2323
                      • Sep 2014
                      • 10
                      sir
                      new machine 9200 copies total
                      that's it
                      • Elmo
                        • Feb 2010
                        • 541
                        in the poor quality areas does any of the image rub off
                        • ramana2323
                          • Sep 2014
                          • 10
                          yes sir
                          if we rub the image at the problematic area
                          the image gets wiped off
                          • Elmo
                            • Feb 2010
                            • 541
                            then that sounds more like a fusing pressure issue
                            • ramana2323
                              • Sep 2014
                              • 10
                              sir
                              what is the solution ..?
