MPC5503 view fuser temp SP mode
  • copier tech
    • 8174
    Quick question if someone knows! long sorry but I'd like to view the fuser temperature while the machine is running & at idle, what's the SP mode for this please?, I have been searching the service manual but can't seem to see it!
    • 37532
    Re: MPC5503 view fuser temp SP mode
    Since you have the Service Manual, look in:
    D146/D147/D148/D149/D150 SYSTEM MAINTENANCE SECTION
    SP MODE TABLES
    MAIN SP TABLES-1
    Page 2-43.
    • turbojetboy
      • Aug 2009
      • 279
      Be aware that there has been firmware updates to correct the issue of unwarranted fuser sc errors. You need to make sure all xx03 models are all up to date with latest firmware. Many of these where popping fuser sc codes every few days, so they had to address it.
        • 37532
        I downloaded today. A number of the update were dated as being released today.
        • copier tech
          • 8174
          The reason I wanted to know, believe it or not, got a call that the customer is burning her hand on the copy paper on exit! so just wanted to show her the fuser temps & explain this is perfectly normal, & that if the machine was to over heat/get to hot it will show an error & shut down.
