MPC 5000 Paper Jam .. need help
  • benghazi08
    [Jamming] MPC 5000 Paper Jam .. need help
    Hello Everyone ^^ ..
    my MPC 5000 Paper Jam every time i order copying , the paper jammed in top auto copier part .
    SEE Attached Pictures .
    Awaiting your reply .
    Regards.
  • Gamut
    • 216
    Re: MPC 5000 Paper Jam .. need help
    Nope, looked at each of those pictures 3 times can't see any paper jammed....
      • 37508
      How about providing us with the jam code so that we can tell where the jam is occurring. If you expect us to do the trouble shooting for you, you need to provide the proper information.
      • SargeNZ
        • May 2012
        • 263
        Looks kinda dusty... hit that thing with some canned air.
        • sandmanmac
          • 3981
          Agreed! Particularly here:
          • Debs1964
            • Oct 2010
            • 1693
            Is there dust on the original length sensors? Those 3 circles on the original input tray.
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • digicor
              • 1156
              your all wrong... the cover for the doc feed shaft is missing, you should not be able to see the shaft in the feed apparatus
              There is supposed to be a long skinny cove over the shaft, so the paper dont get caught up in there...
              • Debs1964
                • Oct 2010
                • 1693
                Well spotted, I did wonder what was taped to the top cover, that cover just slides in place to cover the shaft as pointed out by digicor
                • digicor
                  • 1156
                  good thing its there, and it does just slide into place
                    • 37508
                    I was only looking at the lower side of the paper path. Good eyes.
                    • benghazi08
                      i didn't found the sensor that need to clean ,, i just clean it with air canned and now when i put 100 paper to copy ADF work great until paper 42 it's jam and i get it off and put it back it's goes one until paper 100 ,, that paper it's copied but the original paper jammed in the end cycle in ADF at the output shutter and the machine at that point ask for more originals paper ?? does it should know that paper ended automatically ?
                      • kannuki2
                        • Feb 2012
                        • 398
                        Bengzhazi, see the picture attach. plastic guide is missing.missing part.jpg
                        • benghazi08
                          I was try to fix the problem so i uninstall it but i back it again normal the last paper of every print order still jam while the machine ask for more originals paper .
                          Originally posted by kannuki2
                          Bengzhazi, see the picture attach. plastic guide is missing.[ATTACH=CONFIG]26720[/ATTACH]
                            • 37508
                            There is an arm with a sensor flag that is supposed to hang down from the cover pictured. The pivot shaft for it will sometimes get dislodged and it will not drop down into the original inserted sensor in the lower feed guide. When the last sheet leaves the feeder, the feeder thinks there are more originals. I have had this a couple of times.
