MPC3503 broken part
    • 8164
    [Misc] MPC3503 broken part
    Could someone pls help me identify this broken part, customer has somehow broken the gear AND shaft from the rear of the right door, it's the duplex drive idl gear.
    I have found the gear in the parts manual but need to order the medal plate that has the shaft on it, doesn't seem to be listed.
    Customers AAggghhhhhhhhhh!!!!
  • Bantams
    • Jun 2012
    • 603
    Re: MPC3503 broken part
    Probably comes welded onto the metal plate in the picture
    • Polarbear
      • Feb 2012
      • 1070
      If it isn't in the parts manual, you are going to have to find an engineering shop to help you out....
      Press the GREEN button!!
      • Gift
        • Mar 2011
        • 2459
        D1494648
        bracket:swivel
        d1494653
        tension spring:
        Swivel
        d1494652
        gearulley:swi
        vel
          • 8164
          It's the metal plate I need with the shaft weilded on, might have to order the complete door!
          • Debs1964
            • Oct 2010
            • 1693
            I replaced a whole duplex unit last week because the spot weld was broken on the shaft, I've put the old one in my garage for spare parts, looks like this could prove to be a common problem
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • Polarbear
              • Feb 2012
              • 1070
              I am sure with a little bit of work one should be able to repair the part in question rather than junk a whole duplex?
                • 8164
                I do wonder how they break off!?
                Can I ask what part number you ordered?
                • Debs1964
                  • Oct 2010
                  • 1693
                  I fitted a D1494830 to an MPC6003
                  • pocket aces
                    Ricoh Technician
                    • Nov 2008
                    • 72
                    [ATTACH=CONFIG]26620[/ATTACH]
                    Try this part # D1494750 Bracket motor Duplex
                      • 8164
                      Just looked at the updated parts manual, maybe this could be it!????
                      • Gift
                        • Mar 2011
                        • 2459
                        I'd say that's a good pick!
