Copy a SD Card Printer/Scanner
  • mterrero
    • Sep 2011
    • 60
    [Misc] Copy a SD Card Printer/Scanner
    Hello, I have two SD card for a Ricoh Aficio MPC4500, one is working fine, but the other no, I was trying to clone the good one to the other but didnt worked, has some one try this ?
    The bad SD card is fisically ok, but I dont know why the files become damaged and now I need to clone the good one..
    Any idea ????
  • SargeNZ
    • May 2012
    • 263
    Re: Copy a SD Card Printer/Scanner
    The cards cannot be copied. There are hidden sectors on them that cannot be written or erased.
    • Gift
      • Mar 2011
      • 2459
      That's true - I was able to fix corrupted system/option SD cards with the data content of healthy ones though
        • 37489
        Not if the corrupted portion is one of the hidden sectors.
        mterrero, you will have to order a service replacement SD card. That or send the defective card to Ricoh for repair.
        • Gift
          • Mar 2011
          • 2459
          shure there's no guarantuee this does work - a replacement card via spare part isn't too pricey as worst case
          • Natsu
            • 9
            Hello,I am looking for the sd card for an MP C4500 copier. Can you tell me where I can find her?Thank you
            • anothertech
              • 1769
              I think the card identifies as nonbinary.
                • 37489
                Try the parts catalog for the C4500. It is a listed part of the controller.
