How do scan users move from mp2035 to another?
  • diego_akd2009
    • May 2011
    • 79
    [Dead] How do scan users move from mp2035 to another?
    good morning, what I need is to change a MP2035 that was a customer with a fault that can not be solved in place for another, this client has over 100 users scan and I need to pass to the new 2035, Will changing the hdd is pass data or have to do differently?
  • nmfaxman
    • 1702
    Re: How do scan users move from mp2035 to another?
    Go to the address book in WIM and click on maintenance.
    Backup address book and when you replace the machine, go to address book and restore the data.
    This does work over most models.
    I saved addresses on a 3045 and restored them on a MPC 4500.
    • halbrandenburg
      Bypass Tray Expert
      • Sep 2011
      • 92
      If Maintenance in the WIM does not work for some reason, you can Export Data and Import Data from a CSV file with Smart Device Monitor for Admin, using the Address Management Tool, but you would lose SMB scanning passwords if they are specified within the address book. If the same password is used for all scan addresses you can go into File Transfer in the WIM and specify user and password for SMB one time.
      • sandmanmac
        • 3979
        I'm assuming that the poster is referring to an Aficio 2035, since there is no MP2035?
        That said, unless he's also referring to the 'E' version of the machine, there's also no SMB scanning either.
        Perhaps he'd like to start over and give us a proper description?
        • diego_akd2009
          • May 2011
          • 79
          yes, sorry, I meant a ricoh aficio 2035, can it be done from the browser?
          • halbrandenburg
            Bypass Tray Expert
            • Sep 2011
            • 92
            It can if there is a maintenance option, I'm not sure but it may not. if not, you will have to use the Smart Device Monitor for Admin from either a laptop, or a PC on the network.
            • sandmanmac
              • 3979
              There's no mtce option, and i suspect he's using scanrouter, but he's a little shy to provide many details.
              • halbrandenburg
                Bypass Tray Expert
                • Sep 2011
                • 92
                Ouch you pulled out the S-Word. I just adore Scanrouter LT... I don't run into it often anymore but it still lingers. Most folks don't even know it when they see it. But just look for that Delivery Option = ON
                IF they want to connect with ScanRouter, the hill gets a little steeper.
                • diego_akd2009
                  • May 2011
                  • 79
                  anyone has the link to download the ScanRouter lite v2?
                  • halbrandenburg
                    Bypass Tray Expert
                    • Sep 2011
                    • 92
                    APPLICATION
                    Instructions
                    Limitations
                    Support for ScanRouter Lt ended in 2006 I believe.
                    • sandmanmac
                      • 3979
                      Let me get this straight...You're going to all this trouble to replace a 12 year old outdated and obsolete machine with the exact same model, that operates on a piece of software that has been obsolete, and unsupported for nearly as long?
                      ...AND the machine is used by 100+ people??!! This is the definition of insanity!
                      • halbrandenburg
                        Bypass Tray Expert
                        • Sep 2011
                        • 92
                        Maybe this is kind of like automobiles in Cuba. It must be the only option available.
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          You are correct... 2006 it was.
                          I think it's still on TSSC, but absolutely NOT supported.
                          BTW... You can no longer download SDMA from the Ricoh USA site anymore... It's gone... Removed in favor of DMNX lite (ick).
                            • 37316
                            If they are lucky enough to have the original driver disk, it might be on there.
                            Address book can be backed up to an IC memory card, PCMCIA, if you have one.
                            • halbrandenburg
                              Bypass Tray Expert
                              • Sep 2011
                              • 92
                              Something tells me a Windows 98 ScanRouter server is not a problem at his site.
                              Smart Device Monitor - Not Vintage
