sram has been formatted due to problem with sram
  • copier tech
    • 8172
    I saw the following message on an MPC2051 the machine apears to work fine, im just not sure how to clear it, I tried updating the f/w but the message remains?
    "sram has been formatted due to problem with sram"
  • sandmanmac
    • 3981
    Re: sram has been formatted due to problem with sram
    SRAM ERROR Execute fax SP 5-101
    SRAM ERROR Execute fax SP 5-104
    • NeoMatrix
      Senior Tech.
      • 3513
      Did you install a fax option with this machine?
      • Moza
        • 232
        This shouldn't be a problem, sometimes it happens on installation but will go after a reboot
          • 37532
          If this came up after installing a Fax option and does not go away after cycling power off then on, check the jumper for the SRAM on the Fax board. If this is a machine that has been setting for some time, check the SRAM battery on the Fax board.
          • NeoMatrix
            Senior Tech.
            • 3513
            Fax board battery is low or you didn't set the jumper to on....
            • copier tech
              • 8172
              Thanks for the info, machine has been installed (inc fax) for a couple of years, visited recently to service etc & noticed this message, I don't recall seeing it last visit (2 months ago)
              • mikadonovan
                • May 2008
                • 2931
                Reseat the Fax boards and make sure the MBU is firmly connected to the FCU.
                NEVER ASSUME ANYTHING
                • cadillac2
                  • Oct 2015
                  • 42
                  this usually happens with machines that have been sitting unplugged for a while. In this case the battery on the fax board is trying to retain data and eventually runs down. This is the battery on the small plug-in board on the fax board.
                  It is a 3 volt, but unfortunately soldered in. Your best bet is to solder in a holder for a 3 volt CR2450 Li battery, so in the future a change out will be painless.
