A1035 text printed overlap
  • petrus
    • 155
    Dear friends.
    I have problem with one of my customer outside there.the machine is Aficio 1035.Copy mode is no problem.but when printing from on of pc the text some are joined together.its not in line.it spread.
    and only for one file which created using microsoft word.onather file is ok.
    I have try reinstall the driver and also change the controller pcb.
    But it doesnt work.
    If you have any suggestion please help me
  • rthonpm
    • Aug 2007
    • 2859
    Sounds like an issue with the file more than the machine. Some times print settings are imported for whatever printer was set as the default printer when the file was created. Change the default printer to the 1035 and then copy and paste the text to a new Word document. There was an old Hot Topic post on this issue a couple of years ago.
    • nmfaxman
      • 1702
      Print a Windows test page.
      If it looks good, it is an application problem. Look at the image by doing a print preview.
      Try printing a PDF document.
      • Jomama46
        • 2900
        If you're using the PCL6 driver and the Word program is an older one, drop back to a PCL5e. It is a PCL6 lite.
        Otherwise download and install the latest RPCS driver.
        sigpic
        A+; Network +; PDI+
          • 23010
          I agree with everyone here. Microsoft Word is known to be a problem application as printing goes, but the PCL5e driver might help.
          • Ricoh-ono
            • 339
            I had this problem when trying to print from the latest version of Adobe Reader. Change the print setting to print as image.
            Do what you can, with what you have, where you are. ~Theodore Roosevelt
            • Techos
              • Aug 2025
              Hi
              You must change a parameter in your driver, in the printing quality option,
              true type area, change for "Binary image"
              • petrus
                • 155
                Once again thanks for the tips today.
                Today is my very busy day.so I will check it tomorrow.
                You all are greater then me on this.
