mpc7500 FUNCTIONAL PROBLEM
  • digicor
    • Jul 2008
    • 1159
    Does anyone know what causes the "functional problems with the machine reboot after" progress bars... The client was making copies got to 100, then this,
    hdd? Memory dimms?
  • nmfaxman
    • 1702
    Re: mpc7500 FUNCTIONAL PROBLEM
    Backup Address book and reformat hard drive.
    it could be corrupted.
    • digicor
      • Jul 2008
      • 1159
      COOL,THNX
      • mikedci
        • Jul 2010
        • 227
        Check the sc history? We recently had a bad sensor (sc373) causing the functional problem restart issue.
          • 37532
          There is a SP setting for Auto Reboot on error. Change it so that it displays the Sc in stead of rebooting.
            • 37532
            I got a little more time right now so I looked up the setting. SP 5875 SC Auto Reboot. Set SP 5875-001 to 1.
            • turbojetboy
              • Aug 2009
              • 279
              hdd? Memory dimms?
              I think you will find that you thoroughly need to clean out the itb assy, maybe replace the belt and make sure all belt and id sensors are spotless.
