MP 2501 Faint copies after new drum and developer
  • mtebka
    • Dec 2013
    • 38
    [CQ] MP 2501 Faint copies after new drum and developer
    Hi. I am problems with Aficio mp2501 sp machines. I have changed replaced drum and developer but the copies are coming out faint. Even on a print out. I have initialised I.D. sensor and developer but to no avail. The funny thing is that the same developer works well on brand new machines. Please help
  • Polarbear
    • Feb 2012
    • 1070
    Re: MP 2501 Faint copies after new drum and developer
    Hi
    Which developer did you install? You do know that the MP2501 does not use the same dev as the MP2000?
    Press the GREEN button!!
    • mtebka
      • Dec 2013
      • 38
      yes i used black developer part number d1589640. the only issue I observed after initialising developer was that the vsp was at 1.5. Of which i think is not normal
      • Polarbear
        • Feb 2012
        • 1070
        Hi
        What was the call out for? Was it for CQ?
        Sounds like you could have a faulty TD sensor. Which is stopping the machine form toning up.
          • 37493
          Clean the laser shield glass.
          • laitang
            • Nov 2012
            • 627
            - Clean laser polygon
            - Decrease charge roller bias (2001-1)
            • lef3pap
              • Jan 2012
              • 32
              The first thing that you have to check is if the copy is printed ok on the drum surface.Make a jam yourself and watch.If the copy is ok on the drum then check the transfer unit.If not check the metal behind the pcu that charges charge roller.if everything ok with the pcu go to the laser unit
