any one had this error tran unit seems ok hate these small boxes
mpc305 sc452
Re: mpc305 sc452
Restart the machine & hold the main right door firmly shut does this help?Let us eat, drink, and be merry, because tomorrow we may die!
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
Re: mpc305 sc452
Just for completion...
SC452
[Symptom]
Intermittend SC452 allmost overnight
[Cause]
Sensor below the Transferroller is not OK
Second possibility: the Door close mechanism is not really close
[Action]
Change the sensor or change the Hook's for the Close - Door mechanism
Do not change the Transfer Position Motor how it is written in Service Manual. This takes minimum 2h with no solutionComment
Roy_White
Re: mpc305 sc452
what was the solution? I have a problem C305 with this error, I'd hate to strip the machine to put in the contact motor, if its simpler than that.Comment
Re: mpc305 sc452
Damn machine, I think the worst that RICOH has built in the digital age. I changed the closing of the doors, the sensors and a partner changed the transfer engine without success.
It has served to bend the metal sheet that acts on the sensor of the transfer roller.
1.- Remove the transfer roller.
2.- Fold / Replace the metal sheet where the sensor is placed, upwards.
Can you try telling me what happened? I apologize for my english
Re: mpc305 sc452
Please start you post with brand, model, problem.Comment
