mpc305 sc452
  • slot
    • 341
    mpc305 sc452
    any one had this error tran unit seems ok hate these small boxes
  • ColinLouw
    • Jun 2017
    • 26
    Re: mpc305 sc452
    Do have the same problem,see that rtb change transfer belt to roller..
    Change transfer roller but did not fix error code,machine start up sounds not normal so im checking to go that way...
    So hope anyone had a fix on them..
    Dont like the mpc305
      • 8192
      Re: mpc305 sc452
      Restart the machine & hold the main right door firmly shut does this help?
      • mrwho
        Major Asshole!
        • 4299
        Re: mpc305 sc452
        Thanks for that. Never had this particular problem before, your comment led me right to the solution! Cheers!
        Mascan42
        Ibid
          • 8192
          Re: mpc305 sc452
          • aktasson
            • Feb 2017
            • 201
            Re: mpc305 sc452
            Just for completion...
            SC452
            [Symptom]
            Intermittend SC452 allmost overnight
            [Cause]
            Sensor below the Transferroller is not OK
            Second possibility: the Door close mechanism is not really close
            [Action]
            Change the sensor or change the Hook's for the Close - Door mechanism
            Do not change the Transfer Position Motor how it is written in Service Manual. This takes minimum 2h with no solution
            • aabs
              • Jun 2015
              • 15
              Re: mpc305 sc452
              Had a machine with sc452 due to damaged side cover.
              Now rebuilt with new side cover.
              No sc452 anymore but pale cq at paper transfer.
              PTR bells out to earth so thing bias terminals all good.
              Anyone had issues with PTR unit
              • Roy_White
                Re: mpc305 sc452
                what was the solution? I have a problem C305 with this error, I'd hate to strip the machine to put in the contact motor, if its simpler than that.
                • aguatepe
                  • Jul 2015
                  • 28
                  Re: mpc305 sc452
                  Damn machine, I think the worst that RICOH has built in the digital age. I changed the closing of the doors, the sensors and a partner changed the transfer engine without success.
                  It has served to bend the metal sheet that acts on the sensor of the transfer roller.
                  1.- Remove the transfer roller.
                  2.- Fold / Replace the metal sheet where the sensor is placed, upwards.
                  Can you try telling me what happened? I apologize for my english
                  • Zaxxon
                    • 608
                    Re: mpc305 sc452
                    If you strip it down, be aware of the power switch cables in the psu, the tend to fall off when assembling. It is hard to take the shit apart the second time, I can tell you
                    Please start you post with brand, model, problem.
