machine speed
  • ali.alhaj
    • Mar 2013
    • 34
    machine speed
    hello all
    i need to help me to convert speed mp6001 to mp 7001 or 8001, any idea, in previous version it's easy to convert the speed,
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: machine speed
    Originally posted by ali.alhaj
    hello all
    Not supported. Period.
    You're on your own on this one.
    • Debs1964
      • Oct 2010
      • 1693
      Re: machine speed
      Buy a faster machine in the first place!
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • barratec
        • Jun 2008
        • 162
        Re: machine speed
        Correct the label on the frontside of the machine: change number "6" in number "7" or "8"!
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          Re: machine speed
          Never looked into it, the bets are it is possible as the hardware between the 60ppm and 80ppm looks to be the same.
          It's normally just the paper feed timing / line speed they change.
          But that's all I'm going to say about it as it's a shady practice looked down on just like counter resetting for refurbs.
          • ali.alhaj
            • Mar 2013
            • 34
            Re: machine speed
            no it is not shady quastion, i no need to reset the counter(i know how to reset the counter) this machine are rent and i need to increase the speed, i convert the AF-551 to 700 , AF-2051 to 2075, mp 5500 to mp 7500 , but mp6001 i can not to converted to mp 7001 or mp 8001 (i know mp 9001 is never)
            • rosspt
              • Mar 2012
              • 92
              Re: machine speed
              If you know so much than figure it out. No one on this forum will help with this kind of question.
              • Debs1964
                • Oct 2010
                • 1693
                Re: machine speed
                If it wasn't a shady quastion (sic) then this information would be freely available in service manuals and manufacturers wouldn't sell different speeds (at different prices) in the first place.
                • copier tech
                  • 8237
                  Re: machine speed
                  Buy an NVRAM for the faster machine that will speed it up!
                  • Lagonda
                    • Aug 2008
                    • 1649
                    Re: machine speed
                    As well as a new controller board as there is a separate one listed for each model and I suspect that once a BiCU board has been paired with one model controller board it will be reluctant to work with a faster one.
                    Getting a bit expensive isn't it? Take the tip from the years of knowledge on this site and leave some things well alone.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Re: machine speed
                      My Camel is running too slow....anybody know how to make it run faster?................................whatta dick..!!!
                      • anothertech
                        • 1771
                        Re: machine speed
                        Try swapping out the power cord with the MP9001 cord, it's a NEMA 6-20R, that will allow you to plug it into 240v, that should speed it up nicely!
                        • ZOOTECH
                          Senior member of CRS
                          • 3378
                          Re: machine speed
                          That is mean!!!
                          • collme
                            Ricoh tech
                            • 221
                            Re: machine speed
                            Put it in the back of a lorry and drive down the motorway, that will make the machine go faster
