Ricoh Pro c720
    • 37547
    #16
    Re: Ricoh Pro c720
    Originally posted by jc1print
    im not saying that but trying to search online everyone says they dont work on the C720 so i aint sick just looking for some assistance!!!
    Ricoh Production Printing Support 1-877-318-8968
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      #17
      Re: Ricoh Pro c720
      try to check Sir PSU EA2 - FU3 (facing back side remove the lower right cover the board in the middle) and PSU G - FU2 (facing the back side the board at right underneath of AC Driver Board you can see this boards after you swing the lower right window) both 4A but be more extra carefull when removing this board bracket some connector dont have slack.
      but still its a best to have a trained ricoh engineer look it for you Sir, Good Luck
      but still it
      fix the customer first then fix the machine... its simple and makes life more easy.
      • jc1print
        • Nov 2014
        • 28
        #18
        Re: Ricoh Pro c720
        but still it
        thank you very much i checked both fuses and replaced both awaiting to hopefully hear from a tech i called to check harness cables and switches
        greatly appreciate everyones help on this matter
        • aawwad
          #19
          Re: Ricoh Pro c720
          Hello..
          my name is Ayman, I'm interested in buying Ricoh Pro C720. Is there any difference between this machine and Pro C900 other than the speed?
          • jc1print
            • Nov 2014
            • 28
            #20
            Re: Ricoh Pro c720
            [QUOTE=imaginemoko;447535] try to check Sir PSU EA2 - FU3 (facing back side remove the lower right cover the board in the middle) and PSU G - FU2 (facing the back side the board at right underneath of AC Driver Board you can see this boards after you swing the lower right window) both 4A but be more extra carefull when removing this board bracket some connector dont have slack.
            but still it[/QUOTE
            question on that board there is a light next to the fuse is that suppose to be on when the machine is turned on?
            and can u tell me where are the sensors to this machine for the doors?
            • jc1print
              • Nov 2014
              • 28
              #21
              Re: Ricoh Pro c720
              but still it
              power supply was bad really appreciate it now its just slow booting up hopefully i can get tech to come and tune it up!!!
              • Imprestik
                • Aug 2012
                • 297
                #22
                Re: Ricoh Pro c720
                Going off your picture there bud, do you have any finishing options or a large capacity tray?
                If you do, the image you posted is only showing a base device.
                I hope your under a service agreement because its going to get very expensive for you.....
