Ricoh Pro c720
  • jc1print
    • Nov 2014
    • 28
    Ricoh Pro c720
    can anyone help me with the open door error on the ricoh c720 i can not go past this part as it shows the front doors open abd i cant bypass this point when i turn on the machine, PLEASE!!!
  • rosspt
    • Mar 2012
    • 92
    Re: Ricoh Pro c720
    There's no trick here. Just close the door. If the machine says the door is open then check the door sensors to make sure the tab inside the door is actually triggering them.
    • jc1print
      • Nov 2014
      • 28
      Re: Ricoh Pro c720
      I did that but it still says that door is open the icon is flashing showing there is an open switch it looks like
      • StrippedScrew
        • Jul 2012
        • 58
        Re: Ricoh Pro c720
        um, did you put your meter across the switches and check?
        • fbkhan3
          • May 2012
          • 421
          Re: Ricoh Pro c720
          Sometimes it happens when you have blown fuse in Power Supply Unit ...Read the Blown Fuse Conditions in Service Manual and check the Fuses in PSU. Regard's
          • jc1print
            • Nov 2014
            • 28
            Re: Ricoh Pro c720
            Thank u very much s greatly appreciate everyone's help do u sell ricoh parts too looking a local supplier in nyc
            • anothertech
              • 1771
              Re: Ricoh Pro c720
              Come on, you've got to be kidding right? You can't troubleshoot a C720 by asking a question here and then ordering a the part someone said might possibly
              be the problem. Don't you think maybe you should have a tech look at the machine first? You are not going to be able to keep a C720 running without having a knowledgeable tech on call.
              • jc1print
                • Nov 2014
                • 28
                Re: Ricoh Pro c720
                First of all the only reason I'm writing this is because my tech is very sick n there are not too many ricoh techs in nyc I've been trying to find one but maybe u can answer that question do u know a good tech in nyc instead of being critical about service but I appreciate your help
                I'm just checkling all options until I can replace my tech
                  • 37544
                  Re: Ricoh Pro c720
                  If you are looking for an available Ricoh tech in NYC, you might want to post it in the Employment forum. There are possibly quite a few Ricoh tech here that wouldn't minding moving to NY.
                  • laitang
                    • Nov 2012
                    • 627
                    Re: Ricoh Pro c720
                    Can you show an image of control panel?
                      • 37544
                      Re: Ricoh Pro c720
                      Within 40 miles of New York 10001 zip code there are 3 Ricoh dealers (2 are in NJ), 4 Savin dealers (2 are in NJ) and 11 Lanier dealers all of which are in New York state. Try one of them.
                      • anothertech
                        • 1771
                        Re: Ricoh Pro c720
                        Sounds like jc1print is saying that there is one Ricoh tech covering all of New York City, and he's sick.
                        • jc1print
                          • Nov 2014
                          • 28
                          Re: Ricoh Pro c720
                          here is the cover upon request
                          • jc1print
                            • Nov 2014
                            • 28
                            Re: Ricoh Pro c720
                            can u please tell me how to locate them greatly appreciate your help
                            • jc1print
                              • Nov 2014
                              • 28
                              Re: Ricoh Pro c720
                              im not saying that but trying to search online everyone says they dont work on the C720 so i aint sick just looking for some assistance!!!
