Ricoh Pro c720
Re: Ricoh Pro c720
try to check Sir PSU EA2 - FU3 (facing back side remove the lower right cover the board in the middle) and PSU G - FU2 (facing the back side the board at right underneath of AC Driver Board you can see this boards after you swing the lower right window) both 4A but be more extra carefull when removing this board bracket some connector dont have slack.
but still its a best to have a trained ricoh engineer look it for you Sir, Good Luck
but still itfix the customer first then fix the machine... its simple and makes life more easy.Comment
Re: Ricoh Pro c720
but still it
greatly appreciate everyones help on this matterComment
aawwad
Re: Ricoh Pro c720
Hello..
my name is Ayman, I'm interested in buying Ricoh Pro C720. Is there any difference between this machine and Pro C900 other than the speed?Comment
Re: Ricoh Pro c720
[QUOTE=imaginemoko;447535] try to check Sir PSU EA2 - FU3 (facing back side remove the lower right cover the board in the middle) and PSU G - FU2 (facing the back side the board at right underneath of AC Driver Board you can see this boards after you swing the lower right window) both 4A but be more extra carefull when removing this board bracket some connector dont have slack.
but still it[/QUOTE
question on that board there is a light next to the fuse is that suppose to be on when the machine is turned on?
and can u tell me where are the sensors to this machine for the doors?Last edited by jc1print; 12-11-2014, 02:51 AM.Comment
Re: Ricoh Pro c720
but still itComment
Re: Ricoh Pro c720
Going off your picture there bud, do you have any finishing options or a large capacity tray?
If you do, the image you posted is only showing a base device.
I hope your under a service agreement because its going to get very expensive for you.....Comment
