ricoh aficio 2510 firmware
  • alvin_3000e
    • Dec 2008
    • 31
    Hi,
    I have a ricoh aficio 2510 machine with SD Scanner r4_2.04 version
    I need to update it to SD Scanner r4_2.05 version.
    Need firmware update for that or how to update it.
    Thanks,
    alvintan9
  • Iowatech
    Not a service manager
    • 3930
    Re: ricoh aficio 2510 firmware
    Why do you need to update the firmware?
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      2.05 only cures a very obscure fault, which can easily be ignored.
      • alvin_3000e
        • Dec 2008
        • 31
        Hi Iowatech,
        I have some machine that have the Scanner r4_2.05 firmware and this is able to do smb scan on windows 7 computer. Those with Scanner r4_2.04 can on do smb scan on windows xp, windows 7 fails connection test.
        alvin
        • alvin_3000e
          • Dec 2008
          • 31
          Hi Ruben,
          I try to do smb scan on windows 7 computer it fails connection test. On windows xp machine able to scan. So I think the problem is with the scanner firmware need to update to r4_2.05 to scan on windows 7 computer.
          Thx,
          alvin
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Originally posted by alvin_3000e
            Hi Ruben,
            Thx,
            alvin
            Scanner firmware has nothing to do with SMB scanning, that would be NCS.
            Leave this to Ricoh qualified engineers.
              • 37513
              Hi Ruben,
              Thx,
              alvin
              The usual problem with not being able to scan to SMB on Win 7 with a machine that was able to scan to SMB on windows XP is that win7 requires the use of authentication with a user name AND password. Many people have gotten used to not using a password with XP and do not want to setup a password for 7. To allow a default user to be automatically logged in, Userpasswords2 or netplwiz can be used. If you want to know how to use Userpasswords2 in win 7, just search "Userpasswords2 windows 7".
              • anothertech
                • 1771
                Hi,
                Thanks,
                alvintan9
                As Ruben said, you need NCS frimwar.
                As to how to update it, call your local Ricoh dealer to dispatch a qualified tech.
                • alvin_3000e
                  • Dec 2008
                  • 31
                  Thanks slimslob will checked if that work userpassword2 on windows 7 or netplwiz.
                  On network and sharing I have turn off password and protected sharing on win7.
                  alvin
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    You could also create an entirely new user just for the copier and give it a simple password. If the customer users the icon login screen, the new user will appear on it, you can remove it by editing the registry.
                    regedt32 -> Local Machine -> Software -> Microsoft -> Windows NT -> Winlogon -> create a new Key called SpecialAccounts -> inside that create another new Key called UserList -> create a new DWORD (32bit) Value called the same as the username. Leave the DWORD value as zero to hide.
                      • 37513
                      alvin
                      This only has to do with sharing files with other computers on the network so that other users on the network can read your files. You still have to change user right for reach shared folder if other users are to be allowed to write or modify files.
                      Password protected user name is a requirement of the version of SMB used with Windows 7 and Server 2008. The version of SMB used with Window 8/8.1 and Server 2012 is what requires firmware updates on most older MFPs. I have heard that Windows 8.1 Service Pack 1 has changed that, but have not encountered it as yet.
