MPC4503 Image Defects
  • Bozz
    • Oct 2014
    • 16
    Hey People,
    These are what i am getting out of the machine from test print in serivce mode. Machine only has about 6000 total. Have tried different transfer. If i stop the machine i can see the image on the belt. Its nearly the same on CMY and K. Dont think its drums or fuser. Thinking i need to take the laser unit out and check that? Any other sugestions?
    PRINT EXAMPLES.pdf
  • Gift
    • Mar 2011
    • 2459
    Re: MPC4503 Image Defects
    looks a bit like the machine stands somewhat misaligned on the floor
      • 37653
      To me it looks like development units that do not have enough developer in them.
      • Zeldaman
        • Mar 2011
        • 946
        • copier tech
          • 8238
          When you say "i can see the image on the belt" is it a good solid image or a bad image like your print samples?
          If the image is good on the belt check the transfer roller is fitted correctly, as on the course I fitted it back incorrectly & the samples came out exactly like yours!
          • teebee1234
            • Jul 2008
            • 1670
            If the black is solid then the issue is with the ITB unit, the belt cams up when making color and the black is always in contact with its pcu, maybe the front or rear nylon cam is off or broken. If the black is looking like the color then you most likely have uneven contact with the paper transfer roller. If you remove the ITB unit and turn the belt, are there any ripples in it on the transfer end?
            • Bozz
              • Oct 2014
              • 16
              I have the same machine at the workshop and swapped out the cyan drum unit and it did the same thing. It was a good drum out of a working machine. Just a test. That would mean it wouldnt be the dev unit?
              • Bozz
                • Oct 2014
                • 16
                The image is bad like the samples. I bought the faulty machines transfer back to the workshop and put it in our machine here and it worked fine.
                • Bozz
                  • Oct 2014
                  • 16
                  No ripples. I bought the transfer belt from that machine and put it in our machine in the workshop and it worked fine.
                  • Bozz
                    • Oct 2014
                    • 16
                    Hey Guys,
                    I fixed this problem this morning. I thought when doing A4 tests and stopping it the image on the belt it was bad. After having a better look and doing A3 test i found the image on the belt and the drum looked ok. So i started looking at the paper transfer unit. The documents i have attached show what the problem is but basically the lever that sits under the transfer roller gets stuck down out of position and needs to be pushed back under the plastic guide there for it. Hope this helps someone that has this same problem.
                    • rexrotary
                      • Feb 2015
                      • 19
                      Originally posted by Bozz
                      Hey Guys,
                      [ATTACH=CONFIG]27239[/ATTACH][ATTACH=CONFIG]27240[/ATTACH]
                      Dear all,
                      ihave installed mpc4503 machine, when we try thick paper thick (4) 300 gsm from by pass slidly black line is appearing middle of the paper. any body know the soluation please post.
                      • Zaxxon
                        • 608
                        Originally posted by rexrotary
                        Dear all,
                        It's much appreciated if You would post a new question in a new thread, thanks :-)
                        Please start you post with brand, model, problem.
