Savin C3502 smudge?
  • Bocfus
    • Dec 2014
    • 16
    Savin C3502 smudge?
    Every now and then the customer will get a smudge (smear) on the page. I cant get it to do it for me, the showed me examples. So, I replaced the Black pcu, still does it sometimes. Does anyone have any ideas, almost looks like a charge issue.
  • Zaxxon
    • 608
    Re: Savin C3502 smudge?
    Could you provide an example of the smudge, a picture says more than 1000 word (or something)
    Please start you post with brand, model, problem.
    • Bantams
      • Jun 2012
      • 603
      Check the state of the fuser sleeve.
      • Debs1964
        • Oct 2010
        • 1693
        I've had fusing sleeves give random marks on copies even when they look to be in good condition. It's the sleeve that gives most image quality problems on these machines
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          I've had fusing sleeve, drum and dev unit all cause smudges.
          The fusing sleeve bends, scratches or scuffs.
          The drum cleaning roller gets dirty.
          The dev unit gets covered in toner (worn seal?) and regularly needs cleaning, sometimes the toner drops back onto the drum.
          • wyo19
            • Nov 2012
            • 51
            Make sure ALL firmware is up to date,here are 3 common solutions to intermittent CQ issues...COLD OFFSET IMAGES ON VARIETY TYPES OF DOCUMENTS.pdfDIRTY BACKGROUND.pdfGRANULES OF BLACK TONER APPEAR ON FIRST PRINTED SHEET.pdf
            • copier tech
              • 8171
              Clean the stripper plate, toner gets built up on it & damages the fuser sleeve, if you catch it in time it won't have to replace the sleeve.
                • 37529
                If the smudge appears to always be the same shape and is the same distance from the sides of the page, pull out the ITB and check it for damage.
                • wyo19
                  • Nov 2012
                  • 51
                  Originally posted by wyo19
                  Make sure ALL firmware is up to date,here are 3 common solutions to intermittent CQ issues...[ATTACH]27615[/ATTACH][ATTACH]27616[/ATTACH][ATTACH]27617[/ATTACH]
                  one more hack for fuser belt marks.
                  • Bocfus
                    • Dec 2014
                    • 16
                    Replaced the fuser sleeve, so far so good. I'll keep you updated. Thanks for the help.
                    • Zeldaman
                      • Mar 2011
                      • 946
                      Hi there!
                      Agree with Debs, the sleeveroller may look OK, but everytime the customer prints some more papers the smudge/ghostimage apears.
                      Greetings...
                      • wyo19
                        • Nov 2012
                        • 51
                        The sleeves used to price out around $200.00 they've come down to about $130.00. I've always just used the printer version fuser assembly for $290.00 comes with a fuse and transfer roller. Now I have around 26 copier fusers with bad sleeves.
                        • SargeNZ
                          • May 2012
                          • 263
                          I'm going to chime in for Dev dropping on these models. Split the K drum/dev and tap the dev unit a couple of times onto a sheet of paper, you'll get two nice lines of toner that was built up in the 'trough'.
