ricoh c2550
  • ariosz17
    • May 2016
    • 8
    Re: ricoh c2550
    Originally posted by TonerMunkeh
    Can you print a config page and scan it here? Are you trying to get a connection via DHCP or static? Which board got toasted?
    I can but a little later. Both and nothing on either. Controller board.
    • ariosz17
      • May 2016
      • 8
      Re: ricoh c2550
      Originally posted by wyo19
      If you have a 4 or more port switch try that, wall to switch, switch to copier....
      Oh did but it was still a no go.
      • blee
        Technical Trainer
        • 54
        Re: ricoh c2550
        Make sure your NIC card is enabled in SP mode. I believe it is SP 5-985.
        • wyo19
          • Nov 2012
          • 51
          #19
          Re: ricoh c2550
          Did you connect your laptop to the switch first? make sure you have a complete network, if the board that was fried was it the controller board, if so where did you get the new one from? Ricoh or HYTEC? Can you web into the copier?
