need help
  • eng.mina2011
    • Jul 2025
    need help
    anyone can help me I need to update mp c3500 firmware ????????????
    thanx
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: need help
    thanx
    Well hello to you!!!!!!!!!!!!!!
    Joined 9/13 with no posts????????????? Read the forums for your needed info then introduce yourself and ask for help.
    Frimwar is not free....................
    Mystic Crystal Revelations
      • 37513
      Re: need help
      And he/she/it doesn't provide any information about him/her/itself in his/hers/its profile so we don't even know what part of the universe he/she/it is from.
      • eng.mina2011
        Re: need help
        I know it's not free . just need it if you have it tell me its price
        thanx
        • Elmo
          • Feb 2010
          • 541
          Re: need help
          What fault do you have that makes you think you need to update the firmware
          I Used To Live To Fix Things Now i Fix Things To Live
          • rsyarcia
            Hair Straightener Tech
            • 711
            Re: need help
            what firmware do you need?
            Nobody is perfect..
            • anothertech
              • 1771
              Re: need help
              I think he needs the new firmware for the MPC3500
              • eng.mina2011
                Re: need help
                once it become very slow responding & many error SCs appear as 551 & 549 & 819
                I tried to reset but it wasn't success
                  • 37513
                  Re: need help
                  SC 549 and SC 819 could be firmware related but you would have started getting them about 2 1/2 years ago. SC 549 and 551 are both problems with the fusing unit. SC 819 could be a hardware error in memory or HDD. Download the Goose's Guide and use it to do your trouble shooting. If you still think it is a firmware issue, when you post again list all the current firmwares on the machine and their current version.
                  • techsass
                    • Dec 2010
                    • 248
                    Re: need help
                    The Sc 549 (Rotation) & 551 (Thermistor) are Fuser errors, which is usually caused by a worn out Fuser. The only time I've gotten an Sc 819 on this model is when I tried updating the firmware with an SD card that was too big - over 512mb or had a bad JAVA SD card.
                    For the Fuser codes you have to run Sp5810 to reset it.
                    Sorry if you already know all this, but I don't know if you're a tech or an end user. I think your main problem is Fuser related, not firmware.
