sc672 on a MP 6500 when adding postscript option??
+ More Options
Posts
  • fshead
    • 2360
    hi
    i bought a used ps3 type 7500 on..by and upon installing it"top slot" and left the print/scan card in bottom,i get
    a 672 code.
    i tried it a few times wth no luck..
    i will try it in another machine next week but figured id ck here to see if anyone has seen this before..
    barring it being a defective card
    as i remember all firmware was up to date
    thnx
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: sc672 on a MP 6500 when adding postscript option??
    Make sure you follow 1.22.2 in the Service Manual, if the card is not inserted correctly you could have a bent or damaged contact.
    • fshead
      • 2360
      thnx.
      i have the ps3 in the 1 slot and after ckin it on my laptop i see it shows prnt n scan that
      has me believing it was a merged pull from another copier.
      i was cking the card for the zoffer files that cause the panel message to come up"card was already installed..
      what complicates it more is i have a 2nd card on the 2 slot that i cant read and
      have no idea if it was a ps3,encryption card or something else.
      i didnt have my laptop to ck it in the computer.
      • anothertech
        • 1759
        The service manual says, slot 1=System Card slot 2=option card(in this case, PS3 card) slot 3=service
        if you have more that one option, then you must merge other options to the PS3 card.
        • Tehno copy
          • Jan 2015
          • 3
          Try to put PS card in service slot, that may solve your problem...
          • fshead
            • 2360
            if i remember right there are 2 slots only,and the ps3 card card must be in the top slot after merge the print scan card can be removed from slot 2..slot 2 is also used for firmware updates
