From the troubleshooting guide, Install engine frimwar version 1.108.11 or later. Also references clearing engine memory with sp 5801-2, however I would do frimwar first and if you do clear the engine you better print the non default data list first or have the factory data sheet to restore from. If you don't have one of these doc's you will be screwed, as getting all the settings right will be very very hard to do............
