PRO C900
  • CrapAimer
    • 296
    PRO C900
    Code SC 670 it points to the engine board in the book, before I have to order one has anyone else came across this fault
    Regards
    George
  • anothertech
    • 1771
    Re: PRO C900
    The only thing I see on goose is to check CN420 on IPU to CN206 on BCU
    and one hit for registration section PCB
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: PRO C900
      From the troubleshooting guide, Install engine frimwar version 1.108.11 or later. Also references clearing engine memory with sp 5801-2, however I would do frimwar first and if you do clear the engine you better print the non default data list first or have the factory data sheet to restore from. If you don't have one of these doc's you will be screwed, as getting all the settings right will be very very hard to do............
      Mystic Crystal Revelations
      • CrapAimer
        • 296
        Re: PRO C900
        Stupid Question time. Is the BCU Board also known as the engine board ???
