mfc 2500
  • foudl
    • Mar 2010
    • 138
    [CQ] mfc 2500
    this machine prints black lines , i would like to know if it could be related to the pcu or the transfert belt ,it does the same in color,the transfert belt has never been changed. 0174_001.pdf
    • 37533
    Re: mfc 2500
    Looks like a dirty charge roller to me. If you have 80,000 pages on the black drum unit, then replace it. Otherwise clean the charge roller.
    • rosspt
      • Mar 2012
      • 92
      Re: mfc 2500
      Looks like a charge roller issue in the k drum. Lines that dark and repetitive usually require the drum to be replaced and not just cleaning the charge roller.
      • CrapAimer
        • 296
        Re: mfc 2500
        Would clean the charge roller,
        • foudl
          • Mar 2010
          • 138
          Re: mfc 2500
          Then what about color copies?
            • 37533
            Re: mfc 2500
            If it is just the same black lines on the color copies then correcting the black is all that needs to be done. If you have similar line in one or more of the colors, then for that/those color drum unit(s) you will have to do the same thing as for the black drum.
            • bob marley
              • Jan 2012
              • 1339
              Re: mfc 2500
              Originally posted by foudl
              this machine prints black lines , i would like to know if it could be related to the pcu or the transfert belt ,it does the same in color,the transfert belt has never been changed. [ATTACH]27742[/ATTACH]
              it doesn't seem to be a transfer belt issue . think it is charge roller problem and it is better to change the whole k unit
              Live for yourself and you will live in vain. Live for others, and you will live again
