authentication with destination has failed win 7 aficio mp 4001
  • ESTANISLAOWENENTON
    • May 2025
    hi
    turns out I can not scan a folder in a mp 4000
    the message:
    With The destination authentication has failed.
    check the status and connection .....
    The computer is in domain but when the step- SCAN RECEIVING wokgroup PERFECTLY .
    DOMAIN to relocate again , do not receive the scan and redisplays the error message .
    on other computers that perform this operation working to wonder.
    first sack of the domain , leave it as WORKGROUP and well received .
    DOMAIN I restart , reboot and well .
    but on 2 computers no.
    agradesco suggestions
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: authentication with destination has failed win 7 aficio mp 4001
    Make sure the login you are using has a password. As the computer is on a domain you must add it to the username, e.g. domain\username or username@domain
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Make sure frimwar is up to date, and turn off password protected sharing will make life easier........................ search the forum, there are many posts for this .........................................
      Mystic Crystal Revelations
        tonerbomb
        in this company there are 60 computers which 58 scanner works perfectly.
        in these two that the windows 7 operating system reinstall is causing the problem .
        the folder has all permits, this no password
        ruben
        you give me a good idea
        looking on the internet I found this:
        when you disconnect a computer from the domain , is best done through the Network Identification Wizard , not giving the little button to change hair , because then the team name takes the domain suffix (eg , maquina.dominio.local ) and then becomes "crazy" because users do not coincide with that machine .
        What do you think?
        • anothertech
          • 1757
          Originally posted by ESTANISLAOWENENTON
          tonerbomb
          What do you think?
          hahaha, give the crazy machine Ritalin, then, with this many workstations, setup scanning to a central server, this will head off the problems you get every time you get new computers or reimage the existing machines. Don't forget to update the firmware.
            • 37059
            I have a feeling that the other 58 computers that work are all Windows XP. The version of SMB used on XP does not require a password. The version used on Windows 7 and later versions requires the use of a login with a password.
              thanks for replying
              systems engineer company is very very regular
              Total the idea you give him already suggested , but does not like.
                thanks for replying
                slimslob
                all computers are windows 7
                  • 37059
                  thanks for replying
                  slimslob
                  Then someone has used regedit to disable signed SMB.
                  • rthonpm
                    • Aug 2007
                    • 2847
                    If the computers were in a workgroup network and then added to a domain, is it possible that the scanner is still trying to authenticate with the local machine user accounts? I've seen some sloppy AD integration techniques where the AD user name will match the local account's user name, which just ends up creating all kinds of permissions issues.
                    Have the customer's IT group make sure there are no local accounts on the machine, and that the scan folders are set with read/write permissions for the group Domain Users, or for any user that's using an account to authenticate to the machine.
                      Thanks to all
                      you're right, that the made the Manager d ela network and it worked
                      Many thanks
