nvram data mpc3503
  • en.
    • Jul 2014
    • 124
    nvram data mpc3503
    hi sir
    i need NVRAM DATA FOR MPC3503 ?
    CAN YOU PLEASE SEND OR ATTACHE THE NVRAM DATA TO ME (muthanahusain87@gmail.com )
    BEST REGARDS
  • Zaxxon
    • 608
    Re: nvram data mpc3503
    Originally posted by en.
    hi sir
    BEST REGARDS
    There is a birth certificate under the front cover instruction, re enter this data manually.
    I don't think you can copy nv data from another machine...
    Please start you post with brand, model, problem.
    • bob marley
      • Jan 2012
      • 1339
      Why do u want to replace it ?
      Live for yourself and you will live in vain. Live for others, and you will live again
      • Zaxxon
        • 608
        my guess is that he has cleared it.
        • en.
          • Jul 2014
          • 124
          sir thanks for your response
          i do nvram data upload to sd card because i need to replace nvram
          then i loose sd card and i do by mistake nvram data download from mpc3003 so now the device give me sc995-002
          now i need any nvram data from the same device (mpc3503)
          • turbojetboy
            • Aug 2009
            • 279
            Looking at your previous posts you have quite some history of messing around with nv ram data and memory clears and other repeated and unusual errors. I cant help but think you are trying to "fix" problems with nv ram clears and swapping around nv ram data. Its just a minefield of disaster for you and your customers. I hope you get this sorted, but I suspect these machines are never the same after all this messing around. Playing with nv ram data and mem clears are always a last resort for me. And when I backup an nv ram I always copy it to my laptop and check its valid before doing a mem clear (and in nearly 30 years I can count on one hand how many times I have had to do this).
            • copier tech
              • 8238
              My guess he is trying to reset the main counters 😉
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                It is a rare thing to have to do. Usually it happens after a tech has already jacked up a machine.............
                Mystic Crystal Revelations
                  • 37657
                  The only time we have ever had to replace as NVram one of other techs was getting an uncorrectable controller and went to remove and reseat the NVram only to find that one of the pins was broken off right at the body of the chip. Bad part was we lost all the counters. Good part is we had a non-default print from about a week before.
                  • en.
                    • Jul 2014
                    • 124
                    sir >>all i need now is nvram data from mpc3503 .... any one can give me this data and send it to me to (muthanahusain87@gmail.com) ?
                    thanks
                    • Zeldaman
                      • Mar 2011
                      • 946
                      • en.
                        • Jul 2014
                        • 124
                        thank you sir
                        i now what you mean but in my case im compelled to do nvram data
                        any way which controller mean? you mean (bcu)?
                        • en.
                          • Jul 2014
                          • 124
                          please sir if you have the data on your laptop please send it to me ....or tell me what should i to do te reset sc 995-002
                          • Zeldaman
                            • Mar 2011
                            • 946
                            • en.
                              • Jul 2014
                              • 124
                              thanks sir i do this procedure
                              1- replace nvram
                              2- replaced bcu and i do mach the s.n
                              but now i have three place to change&read s.n
                              1- set
                              2-bcu
                              3-novita
                              now a \ s.n in (1 &2) ia mach but its difrent and not mach with 1&2 (how can Chang the s.n in novita )
                              best regards
