Ricoh Aficio 1075 SC 992
  • powshar
    • Jun 2011
    • 52
    We have a Ricoh Aficio 992 with an SC 992 showing. The manual is not helpful at all, it basically says this is a non-code. Any ideas out there?
    We'd sure appreciate any help! Before the 992, it was jamming consistently right about the registration roller.
  • allan
    RTFM!!
    • 5462
    Re: Ricoh Aficio 1075 SC 992
    Search post for goose guide !
    Whatever
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      have you checked sir if you have developer unit leakage? it may contaminate your paper feed units drive gear with developer that can cause jamming, if happen so cleaned and recondition your registration unit some SC 99* may relate to hard drive gears and motor... anyhow good luck Sir...
      fix the customer first then fix the machine... its simple and makes life more easy.
      • anothertech
        • 1762
        goose says to check/replace charge power pack, replace charge wire.
        • fshead
          • 2372
          on these old units you gotta clean the machine cavity where the drum slides in..all connections and try swapping corona unit if you have cleaned it and chnged the grid n wire..clean drum shaft too
          sounds like arcing might be your issue..
          ive had some hv power packs go
          • bob marley
            • Jan 2012
            • 1339
            It could be a defective software
            Live for yourself and you will live in vain. Live for others, and you will live again
