MPC5000 sc 548
  • digicor
    • Jul 2008
    • 1153
    MPC5000 sc 548
    I have the sc548 on the mp5000, i have changed the heat roller because it was dilapidated off the shaft, ive checked the sensors and cleaned them, they are not loose
    the code is intermittent , is there anything else besides the IH inverter ?
  • Iowatech
    Not a service manager
    • 3930
    Re: MPC5000 sc 548
    Could be that the thermistors are just beginning to wear out. I had that bite me in the sitting muscles enough times that I just replace the thermistors rather than try to clean them anymore.
    However, you might also want to check that the fusing unit isn't binding in some way, and it's sensors can detect proper operation.
      • 37481
      Re: MPC5000 sc 548
      SC 548 is a fusing unit rotation error. The signal from the sensor for the encoder does not change for 0.5 seconds. Could be bearings binding or other excessive load causing the rotation fusing unit to slow down. Also check/clean the sensor.
      • SargeNZ
        • May 2012
        • 263
        Re: MPC5000 sc 548
        Another advocate here for checking the photointerruptor on the machine, the little encoder wheel must engage it properly. It often pops out of its mount from rough handing (slamming the fuser back into the machine)
        • rsyarcia
          Hair Straightener Tech
          • 711
          Re: MPC5000 sc 548
          release the tension springs on both sides of the fusing unit.
          Nobody is perfect..
          • Zaxxon
            • 608
            Re: MPC5000 sc 548
            My vote: Change photo interrupters as they tend to die especially on the earlier models.
            Please start you post with brand, model, problem.
            • Zeldaman
              • Mar 2011
              • 946
              Re: MPC5000 sc 548
              Hi there!
              Remove the covers arround the 2 sensors, clean the area incl. the fans and change the sensors (they were modified with more space beetween the "windows".
              Greetings...
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                Re: MPC5000 sc 548
                Don't forget to check / update the firmware.
                Engine firmware 1.56:08 (and later)
                The occurrence conditions of SC548 (fusing unit rotation error) were
                changed so that it is triggered only when the abnormal signal is detected 4
                times consecutively (previously, it was triggered with just one detection).
                • digicor
                  • Jul 2008
                  • 1153
                  Re: MPC5000 sc 548
                  I changed both thermistors in the re build
                  thanks for all the info,
                  • digicor
                    • Jul 2008
                    • 1153
                    Re: MPC5000 sc 548
                    what do you mean by release? i didnt notice they were adjustable?
                    • rsyarcia
                      • 711
                      Re: MPC5000 sc 548
                      Yes these are not adjustable but what we did is we pull both sides of the spring to loosen the tension of it.
                      Nobody is perfect..
