Ricoh pro1356ex - SC 202
  • rich1106
    • Feb 2014
    • 21
    Hello !
    I have a Ricoh pro 1356ex. C
    onstantly displays the error code 202. But before that ussually shows requires restart and when the machine restart it shows the SC 202.
    Manual Says:
    Polygon Motor Error 1: ON Timeout
    The polygon mirror motor did not reach its operating speed within 20 s after the polygon motor switched on.
    Causes:
    • Connection between the polygon mirror motor control board and the motor is loose, broken, or defective
    • Polygon mirror motor defective
    • Polygon mirror motor control board defective
    • IPU defective
    • BCU defective
    What I Did:
    Change the polygon mirror motor - Continues to show the error
    Change polygon mirror motor control board - Continues to show the error
    IPU Defective - I have not changed yet
    BCU Defective - I have not changed yet
    besides what I have not changed. What advice can you give me about this problem?.
    Thanks for your help!.
    PD: Sorry for my poor english!
    • 37489
    Re: Ricoh pro1356ex - SC 202
    Replace the polygon mirror motor.
    As for the restarting, change SP 5875-001 from 0 (Default setting) to 1.
    On: default: 0 (Reboots automatically) The machine reboots automatically when the machine issues an SC error and logs the SC error code. If the same SC occurs again, the machine displays the error code and does not reboot.
    OFF: 1 Displays error code and does not reboot automatically.
    • rich1106
      • Feb 2014
      • 21
      I have already replaced the polygon mirror motor. I remove the engine from the pro1356 and place it in another machine (I have a MP9000) and it works great. In fact at this time shows the error with the engine of that machine (MP9000)
      thanks for answer!
      • anothertech
        • 1769
        What is this "Engine" you speak of?
        • rich1106
          • Feb 2014
          • 21
          sorry!!... I meant! Polygon motor !!. "In fact at this time shows the error with the polygon mirror motor of that machine (MP9000)"
          • marindam
            • Oct 2013
            • 5
            Try to replace all door switches.
            • Mocafer
              • Mar 2015
              • 23
              Clear the area of ​​laser target your hand inside and clean the lenses and mirrors in this area, wipe the sensor sync. Clean the laser.
              • Codex
                • May 2008
                • 704
                Had the same problem, replaced the door switches and problem is gone!
                Memento Audere Semper
                • mdfurqan2012
                  • 194
                  Try pinched connector of ld unit supply harness from power supply side and also check connector from ipu to ld unit will solve your problem.
