c5502
  • T911
    • Jun 2007
    • 628
    c5502
    This one is smudging black on first print then it clears and copies and prints are perfect. Changed k pcu k developer and transfer blade and its still doing it. Ideas appreciated.
  • turbojetboy
    • Aug 2009
    • 279
    Re: c5502
    100% Fuser, even if it looks perfect - thats the way they are.
    • Zaxxon
      • 608
      Re: c5502
      Had one of these, black smudge only A3 (even when when printing no black)...
      changed fusing sleeve, no luck, still smudge.
      change entire fusing unit, wiiiii smudge gone! But why???
      Please start you post with brand, model, problem.
      • redneckstylin
        • Sep 2011
        • 173
        Re: c5502
        fuser entrance guide is full of toner
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re: c5502
          Yep clean the fuser entrance guides and remove the fuser from the machine and clean the guides between the fuser and transfer section, seen this many times...............
          Mystic Crystal Revelations
          • apump
            • Mar 2009
            • 160
            Re: c5502
            when changing the sleeve replace the pressure roller also. that will fix your smudges, but you will still need to clean the guide where it builds up...
            • anothertech
              • 1771
              Re: c5502
              These sleeves are running longer these days, I changed one today that had 245,000 copies on it. Not too bad.
              • SargeNZ
                • May 2012
                • 263
                Re: c5502
                It probably has a lot to do with the paper stock they are running. I'm still replacing 5502 fusers at 60% of rated life which is a bit crap. Most of our clients with these machines run heavier letterhead or high colour coverage.
                • T911
                  • Jun 2007
                  • 628
                  Re: c5502
                  thanks for the info, what is the fuse for and why is it important that I set sp-3902-018 to 1 before replacing the sleeve assly. are there any counts that need to be reset after replacing the sleeve. thx
                  • copier tech
                    • 8220
                    Re: c5502
                    The fuser sleeves on this series are awfull never last pm life, toner builds up on the guide, this then damages the sleeve causing quality issues
                    • Counsel
                      • Aug 2011
                      • 529
                      Re: c5502
                      My first thought also would have been fuser sleeve and cleaning, sometimes it doesnt even look like a fuser but still is, they were not good on the 4502/5502 models. I will say myself and another tech were going through sleeves a lot due to excessive toner build up around the center of the seperation plate and found you can pretty much just remove the plate and springs and it runs just fine without it and then doesnt scratch the crap out of the fuser sleeve it still doesn't pm most of the time but seems to go a little longer.
                      Almost any quality issue even when it looks like a drum or xfer belt problem ends up being the fuser, almost every call i get on this model is a fuser rebuild, i carry 3 of them in my stock and I only have maybe 10 of these models in my area but can can go through 2-3 replacements in a day. Overall they are a decent machine get some shading and pcu issues once in a while but really if it wasnt for the fuser I would hardly ever get calls on them.
                      • anothertech
                        • 1771
                        Re: c5502
                        How many copies on average are you getting on these sleeves?
                        • Counsel
                          • Aug 2011
                          • 529
                          Re: c5502
                          Its wierd to say but it vaires I have at least 2 of the 10 machines making PM if not more, while the other 8 machines maybe get 50k on the sleeves before they are damaged either by scratches or manage to get crunched and make that tin can noise. So other then the 2 that work for some reason im usually getting 50-80k if im lucky on average. On the ones that were really failing like every 20-30k i removed the seperation plates as test subjects and those have since been running closer to the 80k marks they fail but are no longer getting the gunk buildup that scratches the sleeve surface. I only used the 2 as tests cause they failed early and these customers were regularly using only standard letter and legal paper not special or heavy stocks.
                          • Bantams
                            • Jun 2012
                            • 603
                            Re: c5502
                            I removed the Scrapper plate once on one but it came in a week later for fuser jams seems without the plate they don't like full color pictures very much and it just wraps around the sleeve We just replace the sleeves and the scrappers as a pair now.
                            • Counsel
                              • Aug 2011
                              • 529
                              Re: c5502
                              Were they full bleed or just full page of color. One of the ones I removed was a newspaper small town that also does printshop stuff she ran mostly color, not full bleed stuff but average color and on 11x17 and cardstock and she ran without the sep plate no problem. But I feared it could cause a simlilar issue. It seems to work ok in places where its mostly text documents like a bank or hospital color and full page printing are little if none at all in those locations.
