MPC4500 Asking for K toner
  • copier tech
    • 8222
    I have an mpc4500 that I visited for SC553, I reset this, restarted the mfd & now it just sits asking for k toner but I can feel the toner tube is full!
    reading on this forum I suspect a failed toner pump?
  • walterman
    • 196
    Re: MPC4500 Asking for K toner
    Start with vacuuming out the entire toner system, especially the pump. If that does not work, you may have to replace the toner pump.
    • Zaxxon
      • 608
      Walterman is 100% on the right track.
      Please start you post with brand, model, problem.
      • mrwho
        Major Asshole!
        • 4299
        As a temporary measure, try to disable the toner end detection. Most of the times my customers can keep on using the machine until I stop by to replace the toner pump (don't forget to reenable toner end detection afterwards).
        Mascan42
        Ibid
        • copier tech
          • 8222
          As a temperary messure I manually added toner to the PCDU by pouring toner in by hand!
          When it comes back in i'll try & vav the pump out, I guess i'll need to remove it first?
          • Ahmed Bushara
            • Mar 2015
            • 26
            Hi you need to replace k pump before that you should check. Toner cartridge if it damage or not and clean toner tunk to be shoor to be in save replace toner cartridge. Also
            Thanks and best regards
            Ahmed Bushara
            Electronic Engineering technician
            Mobile: +249-999198804 /+249-123198804
            • bob marley
              • Jan 2012
              • 1339
              It could be a defective pump , toner nozzle assembly, blocked toner tube , or a defective RFID board
              Live for yourself and you will live in vain. Live for others, and you will live again
              • RRodgers
                • Jun 2009
                • 1947
                9 times out of 10 for me it was a bad pump. I've been teaching customers how to check for an empty toner bottle with their two fingers.
                • copier tech
                  • 8222
                  Thanks, I read on here that it is possible to swap the K pump with the M as a test, is this true as the part numbers are different!?
                  • Coptech
                    worker drone
                    • 460
                    I suppose it is possible but it will dump the wrong colored toner that is in it in the wrong dev unit.
                    • Zaxxon
                      • 608
                      I only stock the Y pump and throwing them in mpc 2500 - 3500 not perfect fit but fine with me
                      • copier tech
                        • 8222
                        Once again this site has helped me out!
                        I swapped the M & K pumps round & now the machine adds K toner fine, so obviously now soon will get a magenta toner issue but hopefully the new K pump will arrive before then!
                        Thanks guys 😎
                        • RRodgers
                          • Jun 2009
                          • 1947
                          All the pumps are the same, the only difference is tube length.
                          • copier tech
                            • 8222
                            I noticed this, had to stretch the pipe slightly to make it fit, it's only a temporary meassure
                            • Zaxxon
                              • 608
                              No, the angle of the tube fitting is different on the pumps, but the tube will fit (kind of) anyway
