Light copies only in the morning MP6001 and Aficio 2075
  • vargue
    • Oct 2011
    • 404
    #31
    Re: Light copies only in the morning MP6001 and Aficio 2075
    [QUOTE=vargue;466253]this issue happens to me when yo take drum off for while without any cover then i set it on machine. it's make blurred image .like what yo posted.humidity is too high it's affect on drum formation .
      • 37500
      #32
      I am going to assume that you have already check the connection for the drum and tray heaters to the power supply. You also need to check that the drum heater is present and plugged in to the frame. See parts catalog Frame Section 2 Item 18 for the location of the drum heater on the 6001, upper frame 2 item 12 for the 1075. The connector that plugs into the back wall of the frame is also shown. There is also the possibility that the heater is bad and needs to be replaced.
      • Codex
        • May 2008
        • 704
        #33
        Update: Friday i set the humidity control on 30%.....this morning i went by the customer... And no problems this morning.... Hope it works now!
        Memento Audere Semper
        • Moza
          • 232
          #34
          I had a similar issue a long time ago were we set the weekly timer to switch the machine on a couple of hours prior to the customers starting time. By the time the customer arrived the machine was nice and warm ready to use with no blurred images
          • Codex
            • May 2008
            • 704
            #35
            Moza, if my setting doesn't work i try your suggestion........ I hope summer comes fast this year.... With 45 degrees it's no problem...
            • Moza
              • 232
              #36
              Good luck
              • Codex
                • May 2008
                • 704
                #37
                Slimslob: that was the first thing i've done! But without success, i'm sure the heaters work... Thank you!
                • allan
                  RTFM!!
                  • 5462
                  #38
                  Do they switch the machine off at night? Set the machine to wake 30min before they start working. If i can remember ricoh machine do have a admin setting for that.
                  Whatever
                  • Counsel
                    • Aug 2011
                    • 529
                    #39
                    The issue to me does look like humidity on the drum, we had some color 60ppm machines do the same thing only in the mornings a lot of times the first part of the page was shaded grey or blackish until the machine warmed up our only at that point was to replace the drum with a new one most of the cleaning, waxing, and setting changes only fixed it for a very short time. We usually just have to make the setting changes, and replace the drum itself for the problem to go away.
                    • Codex
                      • May 2008
                      • 704
                      #40
                      • PA3040
                        • Jun 2014
                        • 171
                        #41
                        Grate
                        What is the SP mode number that you set for humidity set?
                          • 37500
                          #42
                          Originally posted by PA3040
                          Grate
                          SP 2901for the MP 6001.
