Ricoh FW780 Wideboy PJ81
  • The-Peanut
    • Aug 2006
    • 192
    i have a problem with the above machine, the machine is coming up with the jam code PJ81 which means jam at the fuser exit sensor check lead edge.
    the lead edge is just at the drum
    i have cleaned both sensors b4 the drum and also checked the fuser exit sensor
    machine has done 10k from new
    an idea's
    cheers
    John
  • copytec
    Is it RJ 81?
    PJ 81 is unknown code.
    Never mind , replace :
    AW02 0024 Photointerruptor in upper paper feed section (on the bottom of dev. unit).
    • The-Peanut
      • Aug 2006
      • 192
      whoops typo errer cough cough
      must admit had that sensor out and cleaned it,
      thanks for the input m8, much appreciated
      will get that ordered and give it a go,
      Cheers
      John
