MPC 4503 while solid full colour auto re-starting add magenta sc 681-12
  • sabah_karim
    • Sep 2009
    • 67
    [Error Code] MPC 4503 while solid full colour auto re-starting add magenta sc 681-12
    Dear All
    MPC 4503 while printing solid full of colour duplex specially. While displaying functional error automatically re-starting with add toner magenta sign and sc registering sc 681-12.
    1. Firmaware updated. 2. Cleaned all four toner chip I.d very properly.
    3. Swap chip I.d magenta with yellow 4. Magenta toner replaced.
    5. Magenta PCDU replaced.
    problem remains same. Please updated with expert advice.
    Thanks You.
  • Imprestik
    • Aug 2012
    • 296
    Re: MPC 4503 while solid full colour auto re-starting add magenta sc 681-12
    There is a firmware fix for this SC, I suggest you begin by updating the firmware.
    If that does not fix it the rubber transport auger many have flipped out of the toner hopper.
    Its a messy job but I have seen this a lot on this device
    • sharpmind
      • Sep 2009
      • 478
      Originally posted by sabah_karim
      Dear All
      Thanks You.
      Make sure that the pins that touch the RFID chip of the toner bottle are not bent. I have encountered that kind of problem. I have found out that one of the pins is bent and it is not touching properly the RFID chip.
      • myxer1234
        • Feb 2013
        • 27
        SC 681.pdfCheck the tech bulletin for this issue. It involves a new kind of tension spring for holding the toner bottle
        • bob marley
          • Jan 2012
          • 1339
          I had the same problem a week ago , because the RFID board. was defective
          Live for yourself and you will live in vain. Live for others, and you will live again
          • copier tech
            • 8132
            Thanks for this info, had this exact issue today toner bottle was popping out & opening the front door very odd!
            • knarfdnul
              • Apr 2011
              • 27
              There is a new bulletin for this - a spring in another form in the function, that turns the toner bottles.
              • DDlan
                • Mar 2017
                • 26
                U copy link.pl.
                thanks.
                • knarfdnul
                  • Apr 2011
                  • 27
                  Originally posted by DDlan
                  U copy link.pl.
                  thanks.
                  I do not have a link and the word file is 1,5MB and I cannot put it here when it is above 1MB - send mail to copytecserviceafdeling@gmail.com and I will mail file to you
                  • rsyarcia
                    Hair Straightener Tech
                    • 711
                    We have this issue before, it was intermittent error. We replaced the development unit, toner hopper, D1495174 - PCB:TCB, toner cartridge, springs(Tech Bul) and updated the firmwares
                    but the error still appears after some time. What we did is manually initialized the td sensor - SP 3030. Machine now ok. I cant see any RFID on the machine.
                    Nobody is perfect..
                    • fabiomurinocamargo
                      • May 2018
                      • 1
                      I did everything that was indicated, but only the manual initialization TD (SP3030) that solved the problem. Thanks for the solution!
                      • rsyarcia
                        • 711
                        Good JOb
                        Nobody is perfect..
