MPC3003 intermitent SC672 error
  • copier tech
    • 8142
    [Error Code] MPC3003 intermitent SC672 error
    I have an on going issue with SC672 on an mpc3003.
    So far I have updated all firmware, currently it's all current.
    I've also removed & refitted all connections on the controller board.
    The code seems to be very random, a couple of times a day, then may go a few days untill it throws sc672 again.
    Has anyone had this issue, I feel it could be a controller, ram or hdd fault but I dont want to order theese parts at a guess!
  • KapeKopyTek
    • Nov 2013
    • 284
    Re: MPC3003 intermitent SC672 error
    SC672-?? T/S guide in the SM pointing to controller mainly, but also indicates op panel may be at fault. Check connections, etc.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Try completely disabling energy saver and AOF and see if it still codes out. The controllers in the 02/03 series are known for this issue. Also make sure all frimwar and JAVA are current..............
      Mystic Crystal Revelations
      • LarryTech
        • Apr 2015
        • 11
        We have had this problem with almost every one of the 03 series our system has purchased. In most of the cases, the local dealer has said that the controller pcb was the problem and was able to get the controller pcb replaced under Ricoh warranty. Ricoh has a 1 year warranty on pcbs or at least that is what they told us. It may be they have some kind of special deal going on with the manufacturer. In any case, ask your local dealer if there is a longer warranty on the circuit boards. Maybe you can get a similar deal for your machines. Good Luck!!
        • copier tech
          • 8142
          This machine is about 2 years old so out of warranty!
          All the fw is up to date
          They're not using any java apps
          • Bantams
            • Jun 2012
            • 603
            do you have any 03s out that are in warrantee still? Just get the sp log data off one of those and claim for a dead controller that's what I would do.
            • Imprestik
              • Aug 2012
              • 297
              1st thing to do is set SP5-191 to 1, this will never turn off the controller board even when the devices goes into energy saver mode
              2nd, I need to know what SC672 is it?
              I have have many of these SC672 errors in the past, the majority of them you can get away with not replacing the controller board, but I need more details such as, is it a SC672-11 for example
              • LarryTech
                • Apr 2015
                • 11
                I went to the Ricoh service manual for the MP C3003 - 6003 and could not find the code, SP5191. Could you tell me where you found this code in the manual? That does sound like a very good way of fixing the problem.
                • stioi
                  system manual
                  • LarryTech
                    • Apr 2015
                    • 11
                    Originally posted by stioi
                    system manual
                    I am confused.....what is a system manual? The only things I found on Ricohs website are a service manual, a parts manual, a PSG (product support guide) and the service bulletins. Where can I acquire a system manual? I would like to see one.
                    • C.Vallon
                      • Jan 2015
                      • 70
                      Troubleshooting the issue suggested this for you, hope that helps. It's the only relevant information I could find for you in the goose guide.
                      Replace Cable Connecting IPU and Operation Panel. Part number D1495225
                      • copier tech
                        • 8142
                        Thanks for all this info.
                        I'll replace the cable first, as obviously that's cheaper, if no luck then i'll order a new controller board.
                        If I do need to replace the controller board what settings are lost, do I simply need to take the memory & NVRAM off the faulty controller & fit it to the new one?
                        • C.Vallon
                          • Jan 2015
                          • 70
                          Generally all settings are stored in the memroy and NVRAM, so swapping those into the new board should be little to no operations change, I believe. However, I'm not sure if the memery and NVRAM will be reset when plugged into the new board for the first time? I haven't had to swap out any boards my self, so I'm of little help to you there man.
                          • jonhiker
                            • 661
                            the memory and NVRAM settings will be transferred over to the new controller. you just may need to update the firmware
                            • copier tech
                              • 8142
                              I have just been back to this one. In SC history there is no record of sc672 only sc988, but the error on the panel is sc672
                              I checked the setting sp5-191 this was already set to 1 so I set it to zero.
                              Also they is newer fw so I updated all again!!!
                              I also removed & refitted all connections on the controller board. Will have to wait & see if it comes back in!
