Pro C900 dev change
  • fatfingers73
    • Feb 2013
    • 219
    [Misc] Pro C900 dev change
    Hello all,
    Probably a stupid question but how do I change the dev on one of these?
    In the service manual it looks like I need 4 old dev bottles for removal, but I only have the 4 new full dev bottles.
    Is there a way round this?
    I thank you
  • anothertech
    • 1768
    Re: Pro C900 dev change
    No easy way that I can think of, you will probably need to find some empty bottles somewhere.
    • totoro
      • 568
      The machine should have come with a long white box that had 4 empty bottles to do the dev changes. You need one keyed to each color. Ask the owner if he has that box.
      Totoro
        • 37477
        Empty bottle is available from parts. G1783115.
        • fatfingers73
          • Feb 2013
          • 219
          Just what I needed. I'm assuming this will fit all four Dev tanks?
          Cheers
            • 37477
            Cheers
            It can be configured for which ever one you need. See bulletin 047. If you are going to do all four you will need four.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              you need a bottle for each color you change. Are you replacing all 4 colors together? and why?
              P.S. always retain the bottles from the new developers you install, for the next developer change.................
              Mystic Crystal Revelations
              • fatfingers73
                • Feb 2013
                • 219
                Yes they've done double their life so I'm doing a full PM.
                I've ordered one bottle to get me started then I'll just keep the empties.
                Cheers.
                • Tonerbomb
                  • Feb 2005
                  • 2589
                  Make sure you run the dev exhaust 2 or 3 times for each color. It helps to pull the dev unit out first and tap on it first to get some of the material freed up in those tiny places in the unit also. When doing the dev fill, agitate the new bottle alot so it is very fluid before attaching it to the dev unit and doing the fill.................
