Ricoh Mpc3000 sc443
  • catgoldfish
    • 70
    [Dead] Ricoh Mpc3000 sc443
    Mpc3000 with a sc443 code. Rep itb unit assembly and still get this code. Any ideas? Thanks.
  • Phil the copy guy
    • Sep 2009
    • 36
    Re: Ricoh Mpc3000 sc443
    Did you run the appropriate service programs after belt replacement?
    • Zaxxon
      • 608
      Lub powder on the belt could be a possibility.
      Please start you post with brand, model, problem.
      • catgoldfish
        • 70
        Well it was giving the code with the old one and i put a brand new assembly not belt in. Do you need to run a program for the whole assembly?
        • catgoldfish
          • 70
          Originally posted by Zaxxon
          [ATTACH=CONFIG]29284[/ATTACH]
          Thanks. Still down
          • Bantams
            • Jun 2012
            • 603
            Does the ITB motor work?
            • tufbnme
              • 493
              Image transfer unit error
              The machine detects the encoder sensor error.
              Defective encoder sensor
              Image transfer unit installation error
              Defective image transfer unit motor
              1. Check if the image transfer unit is correctly set.
              2. Replace the image transfer unit motor.
              3. Replace the image transfer unit.
              • catgoldfish
                • 70
                Yes checked it with input output.
                • Bocfus
                  • Dec 2014
                  • 16
                  There should have been a fuse with the new unit, you must install this on the new unit, that should take care of the code.
                  • tufbnme
                    • 493
                    I've never seen a fuse on the transfer unit, could you elaborate?
                    • Bantams
                      • Jun 2012
                      • 603
                      Just remembered something check the earth wire from the duplex unit if that has a break it can cause all sorts of random codes
                      • bob marley
                        • Jan 2012
                        • 1339
                        It seems that u need to replace encoder sensor
                        Live for yourself and you will live in vain. Live for others, and you will live again
                        • catgoldfish
                          • 70
                          The encoder sensor is on the itb assembly. I've rep the whole thing.
                          • Bocfus
                            • Dec 2014
                            • 16
                            Sorry, I was thinking of the Fuser. Try Changing SP2920/001 to 1. Might have to reboot.
                            • sandmanmac
                              • 3979
                              There's no Fuse on that either, And SP2920 doesn't exist on this model!
