Ricoh Mpc3000 sc443
  • impetus73
    • Mar 2012
    • 75
    #16
    Re: Ricoh Mpc3000 sc443
    Broken encoder sensor. I have had it before.
    • copier tech
      • 8174
      #17
      READ ABOVE! poster has fitted a brand new ITB unit, i.e it has a new encoder sensor!
      • impetus73
        • Mar 2012
        • 75
        #18
        Also, from Goose Guide:
        SC 443 Image transfer unit error - set transfer unit correctly
        SC 443 Image transfer unit error - check CN223-1 for 5vdc sensor opertion, replace IOB if OK
        SC 443 Image transfer unit error - check for binds in belt rotation
        SC 443 Image transfer unit error - replace transfer unit assembly (bad sensor)
        SC 443 Image transfer unit error - replace ITB unit-TB #28
        • catgoldfish
          • 70
          #19
          Yes i've checked all that also. Replaced itb assembly( encoder sensor) . Bicu. Iob. Power supply. Image transfer contact motor. So stressed about this machine. Anything else?
          • catgoldfish
            • 70
            #20
            Reflashed firmware.
            • impetus73
              • Mar 2012
              • 75
              #21
              Maybe there is an error with the new ITB unit? Try another one, or swap the encoder sensor again? Maybe a wire is pinched to ground?
              • catgoldfish
                • 70
                #22
                I've tried 3 of them. I will look for pinched wires.
                • Gary Bowen
                  Bowdog
                  • Mar 2008
                  • 250
                  #23
                  One of your recent posts said you replaced the ITB CONTACT MOTOR. Why that motor and not the Image Transfer Belt Drive Motor? The Contact Motor causes SC442 errors and the Drive Motor could cause SC441/SC443 errors.
                  • catgoldfish
                    • 70
                    #24
                    I did rep both of them. Problem is now fixed. It was the itb interface connector at the back of the machine. There were a couple of metal connectors that were mushed up. Was able to grab it off another machine. Thanks all for the great input.
