Ricoh MP C2800 - 5 minutes to boot
  • jonbonse
    • Jun 2009
    • 737
    #16
    Re: Ricoh MP C2800 - 5 minutes to boot
    Originally posted by withnail
    Set Fuction Priority to Copy in System Settings
    Thanks. It already is set to copy mode as the default screen . . . .
    • jonbonse
      • Jun 2009
      • 737
      #17
      Originally posted by francisco
      format HDD
      Thanks, already tried . . . no difference.
      • jonbonse
        • Jun 2009
        • 737
        #18
        Originally posted by sandmanmac
        x 2
        Had this recently myself on an MP C5000, and updating firmware resolved it
        Thanks, I have updated the system firmware and NIC but don't have the engine firmware to update. . . .
        • jonbonse
          • Jun 2009
          • 737
          #19
          Originally posted by Bantams
          Yes always uninstall the Apps after removing any kind of external device card reader as a machine with equitrac or similar installed will take 5 mins to boot.
          Thanks!
          So would the removal of the apps take place on the machine or does it need to be done via WIM?
          • sandmanmac
            • 3990
            #20
            This jogged my memory, that firmware actually wasn't the cure for my slow booting issue as I stated earlier, but rather that somehow no default function priority was selected The machine would eventually boot to copy mode, but when I went into system settings, the function was NOT selected. I don't know how it happened, or how to duplicate it.
            So have you physically checked that "copy mode" is the default setting? and even if it is, it couldn't hurt to try switching it over to something else, rebooting, and then switching back.
            • Counsel
              • Aug 2011
              • 529
              #21
              I would boot with the network cable unplugged, and check if it will boot faster without the hdd. Most of the time HDD comes in the form of a long please wait screen several mins. That machine should be ready to copy from power in about 30-80 seconds, you might not have sp mode or fax etc right away but the copy screen should be visable in that amount of time, if it just says please wait the whole time i would check without HDD, if faster then try reformat and download stamp data, or another hdd.
              • jonbonse
                • Jun 2009
                • 737
                #22
                Thanks Sandmanmac! This solved it. . .
                There was nothing selected in the function settings. As soon as I selected copy, restarted and back to normal!
                Thank you!!
                • sandmanmac
                  • 3990
                  #23
                  Thank you!!
                  Glad you finally got it sorted out
