SC 399 of MPC 7500
  • Kasun
    • Jun 2015
    • 9
    [Error Code] SC 399 of MPC 7500
    Dear All,
    I am very new to this forum. Recently I had a trouble with error SC 399 of Ricoh MPC 7500. Do you have any possible explanation regarding that error?
    • 37480
    Re: SC 399 of MPC 7500
    From Goose's Guide:
    D014/D015 SC 399 Drum motor error Y - Drum cleaning blade flipped - Replace blade and drum
    D014/D015 SC 399 Drum motor error Y - Replace DTMB pcb (PCB9)
    D014/D015 SC 399 Drum motor error Y - Replace drum motor
    • anothertech
      • 1768
      Yep, Yellow drum motor having a hard time turning,
      SC399 D Drum motor error: Y
      The motor is trying to rotate at power on or during normal operation but
      there is an excessive load on the drum shaft. The motor has no traction
      (due to a bent cleaning blade, for example).
      • TonerMunkeh
        Professional Moron
        • 3865
        In other words, the lovely machine you have is due a PM. Fit the parts these things need according to the PM table. They run much cleaner and happier if you do.
        Hit it.
          • 37480
          If you need a trouble shooting guide for older, 2013 and before, models yu might find this helpful. GG_Oct_2014.zip
          • Kasun
            • Jun 2015
            • 9
            Dear Slimslob,
            Thanks for your clarification and attachment. However, could you please confirm that attachment regarding to MP C7500 machine and its real part number? Moreover, When I interchange Y drum motor with C Drum motor the error was changed to SC 398. So I think it was happened due to old Y defect drum motor. Please confirm my action.
            • jonhiker
              • 661
              Originally posted by Kasun
              Dear Slimslob,
              Yes, the SC398 is the error code for the cyan motor.
              • Kasun
                • Jun 2015
                • 9
                Thank you sir
                  • 37480
                  Dear Slimslob,
                  The XREF work sheet is a cross reference between model numbers and Product Codes.
                  • Kasun
                    • Jun 2015
                    • 9
                    [QUOTE=slimslob;475958]The XREF work sheet is a cross reference between model numbers and Product Codes.
                    According to your experience that motor(Y drum motor) can be defect due to any reason. And I would be greatly appreciate if you could provide FSM and parts catalogue of that model.
                    Thanks again for great help.
