problem with Ricoh Aficio mp c2051
  • impetus73
    • Mar 2012
    • 75
    #31
    Re: problem with Ricoh Aficio mp c2051
    WD-40 works perfect on rubber rollers, it do feel counter-intuitive, but so do quantum mechanics :-)
    Try WD-40 and you get a better life. The rollers does not dry out, and they get a perfect slightly sticky surface that gives a good grip on the paper, without leaving visible residue oil spots.
    It's the same effect as licking your finger when you are flipping thru pages in a book. :-D
      • 37062
      #32
      Originally posted by Kurt1982
      Also, where is paper feed clutch located ??????
      It is a spring clutch in the mount bracket for the paper feed motor.
      • Kurt1982
        • Jun 2015
        • 16
        #33
        [QUOTE=slimslob;476884]It is a spring clutch in the mount bracket for the paper feed motor.[/QUO
        Good. Thank you
        • ewizzy
          Dirty toner monkey
          • Feb 2014
          • 55
          #34
          Can anyone else think of something more horrifying than an end user trying to change tray 1 Spring clutch on an MPC 2051
          Urm.... good luck with changing that...... /walks away whistling.........
