LIGHT COPY (MP C2003SP)
  • sharpmind
    • Sep 2009
    • 478
    Guys, any ideas on how to resolve light copy problem in this model. BW printing is pale. The total prints is around 60k (BW=30k plus, Color=30k plus). I always encounter this kind of problem in this model. Cleaning the optics did not resolve the problem. Is it drum problem?Any settings to be changed in the SP mode?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: LIGHT COPY (MP C2003SP)
    what does the color test page look like?? Was it calibrated before the test page???????? Your click counts show 50/50 use, a bit more color than spec'ed, not that big of a deal though............
    Mystic Crystal Revelations
    • sharpmind
      • Sep 2009
      • 478
      Even it is calibrated (User Tools-Maintenance), the image is still pale. When you check the PRINT TEST PATTERN, the black pattern is very light. After performing several force toner supply for black, I can get good copy. But that is only temporary solution just to show to the customer that the image is good after you service the machine.
        • 37641
        Have you tried cleaning the image density sensor? A dirty ID sensor will cause under toning.
        • copier tech
          • 8236
          I had a simalar issue on a 3003 after doing a forced tnr supply quality was good. So I did & forced supply then reset the PCDU counter & the machine then kept that same toner lever in the dev so all was good.
          • mrwho
            Major Asshole!
            • 4299
            Am having some machines 2003 with the same problem. The one I'm checking now has more or less exactly the same page counts (60k, 90% bw and 10% color). I'm wary of replacing the developing unit as it only has half the specced life.
            The only big difference is that the problem only comes up on bigger print jobs - the machine recovers and maintains the quality on smaller jobs.
            Going to try out Copier Techs solution.
            Sharpmind, ultimately how did you solve this?
            Mascan42
            Ibid
            • Counsel
              • Aug 2011
              • 529
              I had to run a procedure on this model the other day For this exact problem.
              Check value SP 3210-001 if it is 3.5v or higher then do the following
              Sp 3201-001 set value to 4%. (mine was at 9% to start)
              after change make 1 copy or print internal test pattern this applies the value of the change you just made.
              Execute SP 3050-003 three times (Toner add for black i believe it was.)
              Check the value of SP 3200-001
              if the value is 4 or higher your done if it is less then 4 repeat the above steps until it is 4 or higher.
              This is bottom half of TSB #6 on the 2003/2503, the first part of the tsb is for light image only on lead or trail edge, this part i gave you resolves the whole page being light.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Not sure if anyone has taken apart the toner delivery system for one of these but I had an MPC2003 with feint black density.
                We took it to the workshop and found out that the rubber auger in the toner hopper had flipped up.
                The toner delivery system looks very similar to the SPC430DN and when it fails it's the same type of failure.
                Because it was starved of toner those settings would have come in handy Council.
                • ReyTech
                  • Aug 2016
                  • 8
                  You need to replace the pcu, it's copy life is only 60k.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Had exact the same problem on a c2050, cleaned optics: fixed!
                    • Polarbear
                      • Feb 2012
                      • 1070
                      Hi
                      Did you replace the drum units recently? If not physically check that someone else did not. The 2003 has a brass plate in the rear pcu cover. If this cover is swopped with any other model that does not have it, the copies will be light - I have personally seen this. Also if you replaced the drum part of the pcu only, the covers that it comes with. does not have the plate in.
                      Extract from the Ricoh manual on this topic:
                      Press the GREEN button!!
