Ricoh c4502 sc672
  • omorales
    • Mar 2015
    • 86
    Ricoh c4502 sc672
    Help has anyone had this code from start up cannot get into service mode have also tried powering machine on without HDD. I have heard to look at controller.
  • SargeNZ
    • May 2012
    • 263
    Re: Ricoh c4502 sc672
    Service manual says Controller PCB, and I would concur with that. Check the easy things first by swapping the RAM DIMMs from another machine and checking all of the connectors are good. Bent pins in the wiring harnesses are common.
      • 37533
      Controller communication error with the operation panel error. Re-seat connections between controller and BICU, control panel and IPU and BCU.
      • bob marley
        • Jan 2012
        • 1339
        * Controller board installed incorrectly or defective
        * Operation panel connector loose or defective
        * The controller is not completely shutdown when you turn the main switch off
        Live for yourself and you will live in vain. Live for others, and you will live again
        • Debs1964
          • Oct 2010
          • 1693
          I'd put money on it being a faulty controller board
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Do you get a sub code??? 672-xx.......
            Mystic Crystal Revelations
