AF1013 Printing Prob
  • Voltage
    • Jul 2008
    • 282
    Hi Guys
    I have a AF1013 printing the following.
    :%-12345x'pjl job*'pjl set autotraychange=on*pjl set pageprotect=auto*'pjl se
    The PC will start spooling a test page of 196kb and delete it after a few seconds. The above is then printed out. I have tried other drivers and replaced the printer unit. Machine print via LPT1 port.
    Any ideas?
    • 23009
    PostScript Error
    What you're getting is a PostScript error.
    More accurately, the driver is sending PCL (Printer Control Language) print data to a MFP that is set to emulate PostScript. The printer doesn't understand the PCL commands so it just prints the characters of the commands verbatum, exactly as they arrive, usually just a few characters per page on hundreds of pages.
    The solution is to get your driver and printer to speak the same language. There are many ways to do this:
    1) You can set your driver to emulate PostScript, or install a PostScript driver.
    2) You can set your printer to emulate PCL, or if you have the option "Auto" emulation is preferable (the printer can decide for itself which language is appropriate).
    I haven't set up any Ricoh drivers, so it's up to you to figure out the specifics. =^..^=
    • mowpro
      • Aug 2008
      • 43
      Did you print out a config page? it give you an error at the bottom of the page. did you try a differnt pc or a laptop? does it have an ethernet option?
      • nmfaxman
        • 1702
        Print out a NIB summary.
        A PS job without a PS chip prints a boatload of garbage.
        Load PCL5 or PCL6.
        Sell the customer a PS upgrade at cost + 15% and save a lot of problems.
        • Voltage
          • Jul 2008
          • 282
          The print out was a test page. The error was at the top of the page, nothing at the bottom. Did try on laptop and no it does not have an ethernet option.
          • copytec
            Nothing wrong with printer.
            Set up paper size in user option (for both: copy mode and printer mode).
            Read the text: set autotraychange=on, set pageprotect=auto.
