SAMSUNG M3870FD
  • chalky
    • Jul 2015
    • 8
    [CQ] SAMSUNG M3870FD
    I have a Samsung m3870fd internal print good copies using document feeder coming out with lines and not printing on one side I suspect it is the cis on the scanner.Any other suggestions.
    • 22999
    Re: SAMSUNG M3870FD
    It think I would clean all the optics and slit glass first. =^..^=
    • chalky
      • Jul 2015
      • 8
      Re: SAMSUNG M3870FD
      Have done the basic clean optics etc no luck.
        • 22999
        Re: SAMSUNG M3870FD
        I guess I'm not understanding. You are getting lines on one side, but not the other? Is one of the sides of duplex original resulting in a blank copy? If yes, which side? Are you getting any error messages?
        I know this sounds silly, but if there is a printed piece of paper laying under the DF, across the slit glass, you'll get an image of the first side duplex with only lines in the feed direction, but not through the voids, and none of the original image. =^..^=
        • chalky
          • Jul 2015
          • 8
          Re: MPC2051
          Good Day
          Have a Nashua MPC2050 COPIER does not print,the print communication light flashes once and nothing prints have changed printcon bicu board power supply have tested with my lap top and another computer still no luck its not a network problem.
          Any suggestions
          DAVE
            • 22999
            Re: SAMSUNG M3870FD
            I don't think any of the Ricoh guys will be reading your Samsung thread. If you would like Ricoh people to see your thread, you might start a new thread in the Ricoh forum. =^..^=
