SCX-5935FN Clear counter?
  • ZOOTECH
    Senior member of CRS
    • 3375
    I just replaced feed roller kit for tray 1, and I can't find where to clear the feed count.
    Any help will be greatly appreciated.
    Thank you in advance...
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: SCX-5935FN Clear counter?
    To enter Tech service Mode, press “ Menu + # + 1 + 9 + 3 + 4 + Menu” in sequence, and the LCD briefly
    displays ‘Tech Mode’, the machine should be in service mode.
    I'm not sure you can reset the pickup counter, only the page counter ?
    • ZOOTECH
      • 3375
      Thanks, Mat, but this model doesn't have a menu button; I am able to get into service mode (pressing 1 2 3 at the same time), but I don't see
      where I can clear an individual supply kit. When exiting service mode, it does ask if you want to reboot and/or reset counters, but it doesn't.
      I don't want to initialise NVM, but if that is the way to go, I'm ready.
        • 23009
        Diagnostics > Information > HFSI > Pick up Roller Life Page Counter > Reset > OK > Retard Roller Life Page Counter > Reset > OK > Home (to exit).
        Pg 4-36 to 4-37 of the manual. =^..^=
        • ZOOTECH
          • 3375
          Thanks BC, I will give that a try tomorrow.
          • ZOOTECH
            • 3375
            Under HFSI, it only shows ADF roller or Pad reset; I did find the reset though in the admin mode > General tab > Supplies Management > Feed Roller Counter reset.
            Maybe it's a firmware issue, I do have the latest installed.
            I was not able to reference chapter 4 of the service manual (GSPN doesn't have that one).
            As always, I do appreciate your help BC.
              • 23009
              I'm glad you found it. =^..^=
